1 Reply Latest reply on Oct 21, 2014 4:16 AM by vimster303909
    weird problem with animation
    vimster303909
      hi,
      I'm using the new version, and this is a file made with the previous version.
      WeTransfer
      As you can see it is a map with places. If you click a place an overlay appears. If you click another place, the old one goes away, the new one shows up... nothing fancy. I had this working perfectly, but now the code is not right anymore after the upgrade:
      on every place I used to have this code:
      /*   var current=sym.getVariable("current");if(current!=""){sym.getSymbol(current).play("out");}   */
      to animate OUT any current overlay and there is also an action to animate IN the selected plase... But that code is NOT showing in animate (eventhough it does still work)
      My problem is this:
      I had to add 3 ORANGE places and they are not working... or more correctly, I cannot select the orange ones FIRST (nothing happens) but if I select an "old" place first (and the overlay shows up) and THEN select an orange button, it DOES animate correctly!
      very weird...
      Would someone please have a look.
      thanks, j
