10 Replies Latest reply on Mar 22, 2017 7:26 AM by Szalam
    Bridge .ffx files (text effects) no longer open up in After Effects 2014?
    Taiko Man Level 1
      I am having an issue trying to get the text effects (.ffx) in Bridge (that use to open up in After Effects just fine) to open up in After Effects 2014 latest update. Is there a work around, setting or alternative I can use?
        • 1. Re: Bridge .ffx files (text effects) no longer open up in After Effects 2014?
          If you are having problems then you can just use the Animation>Apply Animation Preset and browse to the preset, or if your file structure is correct you will have the FFX available in the Effects and Presets Panel.
          • 2. Re: Bridge .ffx files (text effects) no longer open up in After Effects 2014?
            Taiko Man Level 1
            Hi Rick, Thanks for the answer. Any reason you know of why Bridge doesn't work any more?
            • 5. Re: Bridge .ffx files (text effects) no longer open up in After Effects 2014?
              Taiko Man Level 1
              Here is the log I received with the error:
              10/21/14 10:47:54:850 | [INFO] |  | OOBE | DE |  |  |  | 11806 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
              10/21/14 10:47:54:850 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Visit http://www.adobe.com/go/loganalyzer/ for more information
              10/21/14 10:47:54:850 | [INFO] |  | OOBE | DE |  |  |  | 11806 | START - Installer Session
              10/21/14 10:47:54:850 | [INFO] |  | OOBE | DE |  |  |  | 11806 | RIBS version: 8.0.0.22
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | OSX version: 10.7.5
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Total Timer]
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | CHECK: Single instance running
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | CHECK : Credentials
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Load Deployment File
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | deploymentFile option not given
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | CHECK : Another Native OS installer already running
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Create Required Folders
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Assuming install mode
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Looking up install source path
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Sync Media DB ...
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Sync Media DB]
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Pre check media db sync
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | End of Pre check media db sync. Exit code: 0
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Sync Media DB] took 149 milliseconds (0.149 seconds) DTR = 4241.61 KBPS (4.1422 MBPS)
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Ready to initialize session to start with ...
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [CreatePayloadSession]
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Updated source path: /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1
              10/21/14 10:47:54:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Updating media info for: {5678CF8D-3B5F-4CC6-B150-48945A838E63}
              10/21/14 10:47:54:858 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Ignoring original data since install source is local
              10/21/14 10:47:54:858 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Type: 0, Volume Order: 1, Media Name: AfterEffects_CC_13_1_1_ftr
              10/21/14 10:47:54:858 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Path: /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1/payload s/AdobeAfterEffects13SupportAll-101014104158/AdobeAfterEffects13SupportAll-101014104158.zi p
              10/21/14 10:47:54:858 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Updating media info for: {C135CD0F-ED45-4935-9B71-9D02735BD274}
              10/21/14 10:47:54:859 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Ignoring original data since install source is local
              10/21/14 10:47:54:859 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Type: 0, Volume Order: 1, Media Name: AfterEffects_CC_13_1_1_ftr
              10/21/14 10:47:54:859 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Path: /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1/payload s/AdobeAfterEffects13AllTrial-101014102412/AdobeAfterEffects13AllTrial-101014102412.zip
              10/21/14 10:47:54:859 | [INFO] |  | OOBE | DE |  |  |  | 11806 | --------------------  END  - Updating Media Sources -  END  --------------------
              10/21/14 10:47:54:866 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Supported RIBS version range: [0.0.0.0,8.0.0.22]
              10/21/14 10:47:54:867 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ----------------- CreatePayloadSession: machine is x86 ---------------
              10/21/14 10:48:00:136 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ______ Verify Dependency Subscribers ______
              10/21/14 10:48:00:136 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
              10/21/14 10:48:00:136 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63}: 0 (0,0)
              10/21/14 10:48:00:136 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}: 0 (0,0)
              10/21/14 10:48:00:136 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
              10/21/14 10:48:00:137 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Patch Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63} can be applied to product Adobe After Effects CC 2014 Support 13.0.0.0 {A55FF34C-8AA8-4BE2-ABCC-12BE48AE8DD5}
              10/21/14 10:48:00:141 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Patch Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274} can be applied to product Adobe After Effects CC 2014 13.0.0.0 {2B22C750-5C3B-4738-B621-BA786AC7A494}
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Setting property "installSourcePath" to: /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Setting property "mode" to: silent
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Setting property "updateManifestPath" to: /Users/adam/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeAfterEffects-13.0.0-Trial/13.1.1/13.1.1.xml
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Setting property "workflow" to: updater
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Overwrite property "extensionsOnly" to: 1
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Overwrite property "mode" to: silent
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Overwrite property "patchesOnly" to: 1
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Overwrite property "updateManifestPath" to: /Users/adam/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeAfterEffects-13.0.0-Trial/13.1.1/13.1.1.xml
              10/21/14 10:48:11:117 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Overwrite property "workflow" to: updater
              10/21/14 10:48:11:118 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Found payload actions:
              10/21/14 10:48:11:118 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Deciding what installer mode to use...
              10/21/14 10:48:11:190 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN Setting requested payload actions
              10/21/14 10:48:11:191 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Value returned on lookup of payload: Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63} is: true
              10/21/14 10:48:11:191 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Action string for Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63}  is install
              10/21/14 10:48:11:191 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Value returned on lookup of payload: Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274} is: false
              10/21/14 10:48:11:191 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Action string for Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}  is install
              10/21/14 10:48:11:197 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END Setting requested payload actions
              10/21/14 10:48:11:198 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Collected advanced path check information for INSTALLDIR
              10/21/14 10:48:11:198 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR is a well-formed path
              10/21/14 10:48:11:199 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR is not the root path
              10/21/14 10:48:11:199 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR is on a local volume
              10/21/14 10:48:11:199 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR is on a writable volume
              10/21/14 10:48:11:199 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR is not on a case sensitive volume
              10/21/14 10:48:11:199 | [INFO] |  | OOBE | DE |  |  |  | 11806 | INSTALLDIR passed path basic path validation: /Applications
              10/21/14 10:48:11:275 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [System check :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:11:280 | [INFO] |  | OOBE | DE |  |  |  | 11806 | In InstallPreSystemCheckProc
              10/21/14 10:48:11:280 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Custom action return code: 0
              10/21/14 10:48:11:281 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [System check :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 5 milliseconds (0.005 seconds)
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN InstallOperationsQueue Unordered operations
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63}:  with operation repair
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}:  with operation install
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END InstallOperationsQueue Unordered operations
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN InstallOperationsQueue Ordered operations
              10/21/14 10:48:11:540 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END InstallOperationsQueue Ordered operations
              10/21/14 10:48:11:541 | [WARN] |  | OOBE | DE |  |  |  | 11806 | DW035: Patcher: Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Payloads passed preflight validation.
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Call PreSession Custom Hook
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Pre session :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | In InstallSessionOpenProc
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Custom action return code: 0
              10/21/14 10:48:11:631 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Pre session :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 0 milliseconds (0 seconds)
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN InstallOperationsQueue Unordered operations
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63}:  with operation repair
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 |   Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}:  with operation install
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END InstallOperationsQueue Unordered operations
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 | BEGIN InstallOperationsQueue Ordered operations
              10/21/14 10:48:11:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END InstallOperationsQueue Ordered operations
              10/21/14 10:48:11:857 | [WARN] |  | OOBE | DE |  |  |  | 11806 | DW035: Patcher: Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
              10/21/14 10:48:11:857 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Skipping payload Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll 13.1.1.0 {5678CF8D-3B5F-4CC6-B150-48945A838E63} as payload is not cached
              10/21/14 10:48:12:155 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Calling the custom action code for pre-install for payload Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}
              10/21/14 10:48:12:156 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Pre payload :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:12:156 | [INFO] |  | OOBE | DE |  |  |  | 11806 | In PrePayloadInstallProc
              10/21/14 10:48:12:156 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Custom action return code: 0
              10/21/14 10:48:12:156 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Pre payload :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 0 milliseconds (0 seconds)
              10/21/14 10:48:12:156 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Payload Operation :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:12:165 | [INFO] |  | OOBE | DE |  |  |  | 12205 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
              10/21/14 10:48:12:165 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Installer Operation: PayloadInstaller
              10/21/14 10:48:12:165 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Request to install payload
              10/21/14 10:48:12:193 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Payload Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
              10/21/14 10:48:42:884 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Extracting assets complete. Number assets: 1
              10/21/14 10:48:42:885 | [INFO] |  | OOBE | DE |  |  |  | 12205 | CustomizedPatch property not found in database
              10/21/14 10:48:43:146 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Beginning installation for payload at /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1/payload s/AdobeAfterEffects13AllTrial-101014102412/Install.db
              10/21/14 10:48:43:454 | [ERROR] |  | OOBE | DE |  |  |  | 12205 | DS015: Unable to read symlink target of source file "/Applications/Adobe After Effects CC 2014/Plug-ins/Effects/mochaAE/(Mocha Support)/mocha AE CC.app/Contents/MacOS/mediaioserver.app/Contents/CodeResources"(Seq 212)
              10/21/14 10:48:43:454 | [WARN] |  | OOBE | DE |  |  |  | 12205 | DW063: Command ARKCopySymlinkCommand failed.(Seq 212)
              10/21/14 10:48:43:454 | [INFO] |  | OOBE | DE |  |  |  | 12205 | Completing installation for payload at /Users/adam/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.1.1/payload s/AdobeAfterEffects13AllTrial-101014102412/Install.db
              10/21/14 10:48:51:624 | [INFO] |  | OOBE | DE |  |  |  | 11806 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
              10/21/14 10:48:51:624 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Payload Operation :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 39467 milliseconds (39.467 seconds) DTR = 8703.17 KBPS (8.49919 MBPS)
              10/21/14 10:48:51:632 | [INFO] |  | OOBE | DE |  |  |  | 11806 | User specified overrideFile:
              10/21/14 10:48:51:637 | [INFO] |  | OOBE | DE |  |  |  | 11806 | The csu inventory was not updated for payload Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}, value of local var is -1
              10/21/14 10:48:51:637 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Calling the ROLLBACK custom action code for pre-install for payload Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274}
              10/21/14 10:48:51:638 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Pre payload :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:51:638 | [INFO] |  | OOBE | DE |  |  |  | 11806 | In PrePayloadInstallProc
              10/21/14 10:48:51:638 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Custom action return code: 0
              10/21/14 10:48:51:638 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Pre payload :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 0 milliseconds (0 seconds)
              10/21/14 10:48:51:868 | [INFO] |  | OOBE | DE |  |  |  | 11806 | No operation.  We're done:
              10/21/14 10:48:53:891 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Total components installed: 0
              10/21/14 10:48:53:891 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Total components repaired: 0
              10/21/14 10:48:53:891 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Total components removed: 0
              10/21/14 10:48:53:891 | [WARN] |  | OOBE | DE |  |  |  | 11806 | DW050: The following payload errors were found during install:
              10/21/14 10:48:53:891 | [WARN] |  | OOBE | DE |  |  |  | 11806 | DW050:  - Adobe After Effects CC 2014 Support_13.1.1_AdobeAfterEffects13SupportAll: Patch already installed
              10/21/14 10:48:53:891 | [WARN] |  | OOBE | DE |  |  |  | 11806 | DW050:  - Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial: Install failed
              10/21/14 10:48:53:891 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Call PostSession Custom Hook
              10/21/14 10:48:53:891 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ::START TIMER:: [Post session :{C135CD0F-ED45-4935-9B71-9D02735BD274}]
              10/21/14 10:48:53:892 | [INFO] |  | OOBE | DE |  |  |  | 11806 | In InstallSessionCloseProc
              10/21/14 10:48:53:892 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Custom action return code: 0
              10/21/14 10:48:53:892 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Post session :{C135CD0F-ED45-4935-9B71-9D02735BD274}] took 0 milliseconds (0 seconds)
              10/21/14 10:48:53:892 | [INFO] |  | OOBE | DE |  |  |  | 11806 | :: END TIMER :: [Total Timer] took 61758 milliseconds (61.758 seconds) DTR = 5778.75 KBPS (5.64331 MBPS)
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | -------------------------------------- Summary --------------------------------------
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 |  - 0 fatal error(s), 1 error(s)
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | OSX version: 10.7.5
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ----------- Payload: Adobe After Effects CC 2014_13.1.1_AdobeAfterEffects13AllTrial 13.1.1.0 {C135CD0F-ED45-4935-9B71-9D02735BD274} -----------
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | ERROR: DS015: Unable to read symlink target of source file "/Applications/Adobe After Effects CC 2014/Plug-ins/Effects/mochaAE/(Mocha Support)/mocha AE CC.app/Contents/MacOS/mediaioserver.app/Contents/CodeResources"(Seq 212)
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Please search the above error string(s) to find when the error occurred.
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | These errors resulted in installer Exit Code mentioned below.
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | -------------------------------------------------------------------------------------
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Exit Code: 7 - Unable to complete Silent workflow.
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | Please see specific errors for troubleshooting. For example, ERROR: DS015 ...
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
              10/21/14 10:48:54:895 | [INFO] |  | OOBE | DE |  |  |  | 11806 | END - Installer Session
              • 6. Re: Bridge .ffx files (text effects) no longer open up in After Effects 2014?
                Tim Kurkoski Adobe Employee
                This is fixed in the After Effects 2014.2 (13.2) update, which is now available.
                Details here: http://adobe.ly/1IVopxh
                • 10. Re: Bridge .ffx files (text effects) no longer open up in After Effects 2014?
                  You've twirled down the wrong text area. You want to twirl down the Animation Presets at the top and find the text folder in there.
