0 Replies Latest reply on Oct 20, 2014 12:20 PM by tehinternets
    How to handle 0 records returned via ODBC connection?
    tehinternets Level 1
      Hello,
      I am connecting my form via ODBC to an MS Access database with FormCalc XFA.  I know that's not ideal, but it works.   I am stuck however on how to handle errors when the form is not able to return a record due to a bad search string.
      Typically I am expecting one unique record to be returned, however at times there is no match based upon what the user has entered into the search field.  I am trying to 'catch' the error and give them a custom message I write, or no error at all.
      My Data Connection name is:   EstabSearchResults
      My search field name is:   EstabSearchField
      Here is what is run on the On Exit event when the user leaves the EstabSearchField:
      var oDC = Ref($sourceSet.EstabSearchResults.clone(1))
      oDC.#command.query.commandType = "text"
      oDC.#command.query.select = concat("SELECT Blah, BLah2, Foo, Bar FROM TableName WHERE (Something LIKE '",EstabSearchField.rawValue,"');")
      oDC.open()
      oDC.first()
      If there's now records however, I get:    [A whole bunch of Adobe gibberish that makes sense to end-users]  Error:  No records in datasource.
      I'm having a difficult time coming up with a way to handle it when there is no records and perform addition customized logic if that happens.
      Any ideas?
      Thanks!
      -Mike
