13 Replies Latest reply on Oct 22, 2014 7:01 AM by QuadrantProductions
    can we bind mouse events to a dynamic set of instructions in a JSON call?
    QuadrantProductions Level 1
      //method dynamically loads JSON file with all items and iterates them on stage
      $.getJSON('staffnames.json', function(data){
        for(var i=0; i<data.length; i++)
        var s = sym.createChildSymbol("teamThumb", "Stage");
        s.$("holder").css({"background-image":"url('"+data[i].image+"')"});
        s.$("thename").html(data[i].thename);
        s.$("thetitle").html(data[i].thetitle);
        s.$("certifications").html(data[i].certifications);
        s.$("biography").html(data[i].biography);
        s.getSymbolElement().css({"position":"absolute",
        "left":i*150+"px",
        "top":"220px"
      Using the above code block which dynamically loads the data in an array held inside a JSON file, how would we write a further instruction so that an additional data object in the JSON array could be loaded onto a stage element (outside of the symbol called teamThumb here).
      So specifically, the data object "biography" is inside the array that is being loaded above.  And 1 symbol for each data block in the JSON file is being loaded.  Now I need to add a command that would load the "Biography" line item say on a mouse click.
      Here's the whole code block view on the compositionReady
        "left":i*150+"px",
        "top":"220px"
      //  BELOW IS PHASE 2.  For absolute positioning.
      /* below is what I've figured out so far for manually loading the individual symbols.  I would want to do that so I could control the position of how the loading symbols that are going to be populated by JSON data woudl be discplayed.
      //method dynamically loads JSON file with all items but manually calls them in place
        var s2 = sym.getSymbol("teamThumb1", "Stage");
        s2.$("holder").css({"background-image":"url('"+data[0].image+"')"});
        s2.$("thename").html(data[0].thename);
        s2.$("thetitle").html(data[0].thetitle);
        s2.$("certifications").html(data[0].certifications);
        // this is saying the symbol name, id name's html should be the corresponding data name in the array
      Any assistance is most appreciated!
        • 1. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
          resdesign Adobe Community Professional & MVP
          For you last question, why not use a container insted of the stage? That way you position your container and your data will load at (0.0) in that container.
          • 2. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
            resdesign will do!  Great suggestion.  Just now I need to first figure out how too change the text on the external text object.
            • 3. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
              I am wondering if you could not load your bio with the rest and then load that text on an event pertaining to a symbol that you load or for which you manipulate the opacity.
              • 4. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                I'll try to understand your structure and post a sample tomorrow.
                • 5. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                  Where / How can I upload a file (animate file) so you can see what I've done.  I just implemented your idea of nesting the calls inside an object instead of rendering them to the stage and that worked great.  If I zipped the whole project, it would give you a better idea... See if you can all files are now in this dropbox link https://www.dropbox.com/sh/mltt8m5x2ihe3r1/AABfr-pGrl1FCzycv9zWpwNZa?dl=0... should save you some time.
                  • 6. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                      var s = sym.createChildSymbol("teamThumb", "bigholder");
                      "left":i*180+"px",
                      "top":"30px"
                    /* THIS WORKS
                    /* THIS WORKS $.getJSON('staffnames.json', function(data){
                      "left":i*180+"px",
                      "top":"30px"
                    //method dynamically loads JSON file with all items but manually calls them in place*/
                    // AS YOU CAN SEE ALOT OF REDUNDANCY.  How do I effect the same dynamic control as above but with this kind of functionality
                      var myclip = sym.$("teamThumb1");
                      var s2 = sym.getSymbol("teamThumb1");
                      s2.$("biography").html(data[0].biography);
                    // insert below
                      //Sample Code
                      //element=sym.$("teamThumb1");
                      myclip.on({
                             mouseenter: function() {
                                 // Do something
                                 sym.$("biographyareaCopy").html(data[0].biography);
                                 sym.$("thename").html(data[0].thename);
                                 //alert( "hovered over a div" );
                             mouseleave: function() {
                                 // Do something
                                 //alert( "mouse left a div" );
                             click: function() {
                                 // Do something
                                 //alert( "clicked on a div" );
                    // end sample code
                    //insert above
                    //  testing 2nd symbol
                      var myclip2 = sym.$("teamThumb2");
                      var s2 = sym.getSymbol("teamThumb2");
                      s2.$("holder").css({"background-image":"url('"+data[1].image+"')"});
                      s2.$("thename").html(data[1].thename);
                      s2.$("thetitle").html(data[1].thetitle);
                      s2.$("certifications").html(data[1].certifications);
                      s2.$("biography").html(data[1].biography);
                    // insert below
                      //Sample Code
                      //element=sym.$("teamThumb2");
                      myclip2.on({
                                 // Do something
                                 sym.$("biographyareaCopy").html(data[1].biography);
                                 sym.$("thename").html(data[1].thename);
                                 // Do something
                             click: function() {
                                 // Do something
                    // end sample code
                    //insert above
                    • 7. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                      You can PM me a link to a zipped file from a cloud storage of your choice.
                      • 8. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                        You can zip your file and put it on a cloud storage of your choice and PM me the link.
                        On Mon, Oct 20, 2014 at 5:15 PM, QuadrantProductions
                        • 9. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                          Zoze Level 2
                          you have to add class or add id and call it when you need to so it.
                          eg.
                          s.attr("id", "nameofid")
                          and then call as
                          sym.$("#nameofid0").hide();  // 0 is the data index of the json
                          • 10. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                            Zoze Level 2
                            /* THIS WORKS
                              "left":i*180+"px",
                              "top":"30px"
                            s.attr("id", "nameofid");
                            s.$("thename").data("jsonindex", i);
                            s.$("thetitle").click("click", function (e) {
                              if ($(this).data("jsonindex") == 0) {
                                 sym.$("#nameofid35").hide();
                            else if ($(this).data("jsonindex") == 1) {
                                 sym.$("#nameofid55").hide();
                            sym.$("#nameofid45").show();
                            • 11. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                              I just tried this but get an error on line 27 else if ($(this).data("jsonindex") == 1) {
                              Thank you for posting but , I'm not sure I understand this example.
                              • 12. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                                Zoze Level 2
                                upload again the project file if you haven't found an answer yet, to see if i can help
                                • 13. Re: can we bind mouse events to a dynamic set of instructions in a JSON call?
                                  Just sent you the link.  Thanks for offering to look!
