1 Reply Latest reply on Oct 21, 2014 8:34 AM by JJMack
    How to Horizontally attribute any layers
    YaoyongYu
      How to Horizontally attribute any layers with scripting
        • 1. Re: How to Horizontally attribute any layers
          Make a selection and align the layer to it using action manager code. This code should show I  how it can be used, The top part is missing supporting code but its the align function Paul posted that you want.
          // Add Filename Text if called for
          if ( MICollage.msgPnl.StampImage.st.value) {
            stampFilename(textFont,textSizeFactor,textColor,Name);
            loadAlpha("Image " + imageNumber);
            var Position = Number(MICollage.msgPnl.grp5a.dd1.selection.index) + 1;
            switch (Position){
            case 1 : align('AdLf'); align('AdTp'); break;
            case 2 : align('AdCH'); align('AdTp'); break;
            case 3 : align('AdRg'); align('AdTp'); break;
            case 4 : align('AdLf'); align('AdCV'); break;
            case 5 : align('AdCH'); align('AdCV'); activeDocument.selection.deselect(); activeDocument.activeLayer.rotate(textAngle); break;
            case 6 : align('AdRg'); align('AdCV'); break;
            case 7 : align('AdLf'); align('AdBt'); break;
            case 8 : align('AdCH'); align('AdBt'); break;
            case 9 : align('AdRg'); align('AdBt'); break;
            default : break;
            // could add code to do something with the image prefix info if it exists in prefixlist
            if ( prefixlist[imageNumber -1] != undefined ) {}
            // Add text Layer's layer style
            addStyle(textStyle);
          function align(method) {
            var desc = new ActionDescriptor();
            var ref = new ActionReference();
            ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
            desc.putReference( charIDToTypeID( "null" ), ref );
            desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
            try{
            executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );
            }catch(e){}
