1. Re: Jpeg images not showing up
99jon Oct 21, 2014 9:41 AM (in response to Reese Richardson)What type of raw files are they? Are you using Copy in the import dialog? Are the jpegs identical e.g. you had the camera set to shoot raw+jpeg simultaneously?
What happens if you select all and then import the folder contents?
When you select a raw image does the metadata panel (see image) show sidecar files for Jpeg and XMP?
2. Re: Jpeg images not showing up
Reese Richardson Oct 21, 2014 10:04 AM (in response to 99jon)What I do I like bridge better so I shoot in Canon RAW CR2. So I import from the camera into Bridge work the images up in Adobe Photoshop in RAW and save the image as a jpeg using the lower left hand side of RAW after images have be corrected . So out of 83 images that a RAW. 32 were saved as a jpeg but they do not show up when using Lightroom. When I looked at image in file folders that were shoot in jpeg not RAW all images show up.
Hope this makes sense, I use Lightroom to put image on my web site using Publish
3. Re: Jpeg images not showing up
99jon Oct 21, 2014 10:14 AM (in response to Reese Richardson)It’s an unusual workflow and unless there is some conflict between metadata in Bridge and Lightroom the independently created jpegs should import.
You could go to:
Edit >> Preferences >> General
Put a checkmark against “Treat jpeg files next to Raw as separate photos” and then click OK.
If that makes no difference I suggest you move the jpeg files to a separate folder and import the raw folder and jpeg folders individually using Import >> Add
It will then be possible to drag images from each folder into a single Publish Service collection for uploading.
4. Re: Jpeg images not showing up
Reese Richardson Oct 21, 2014 3:45 PM (in response to 99jon)That works checked box jpeg show up now. Like the bigger screen in Photoshop RAW let me see what I'm doing should study the program more maybe I'd like it
