7 Replies Latest reply: Oct 21, 2014 10:51 AM by Ellis home RSS
    Setting a corner option (on rectangle) to greater than 0.693pt?
    shawninvancouver Community Member
      Hello all,
      This is probably an amateur question.
      I am trying to make a long ellipse-like shape that isn't a sharp (on the ends) as the ellipse shape. Using the rectangle shape actually gets me closer to the desired shape. However, I need a radius greater than 0.693pt... it seems odd that I can increase the value beyond this but the actual roundness isn't affected beyond this value.
      I could solve the problem by creating more anchor points and manually creating the shape that I require but it will be difficult to achieve perfect symmetry and seems like a lot of effort for a shape that should be easy to draw (as it was in the Snagit example attached).
      Thanks so much!
