6 Replies Latest reply on Oct 22, 2014 1:00 PM by JJMack
    PS removes selections where there are none
    Robert1767
      I use photoshop CC, and I have a problem with almost all of my pictures:
      This happens when I want to save the picture...
      anyone?
      thanks,
      Robert
        • 2. Re: PS removes selections where there are none
          Robert1767 Level 1
          I use CC, so everytime there's an update, I immediately do that, so I guess I have always the latest version. the problem occured for the first time a couple of weeks ago; usely after importing my pictures from my camera. I shoot in RAW, and then select and improve the photo's I want/need, and save them as JPG. Then, when I want to use the picture in a project, and save the picture, sometimes the problem appears...
          • 3. Re: PS removes selections where there are none
            Please use Photoshop menu help>System Info and post results here.
            • 4. Re: PS removes selections where there are none
              c.pfaffenbichler Level 9
              Also if you intend to do further work on an image saving as jpg seems ill-advised.
              • 5. Re: PS removes selections where there are none
                Robert1767 Level 1
                It is in Dutch, I hope it's readable...
                not only the jpg, but every format gives the same result.. If I have to do other work with the file, ofcourse I don't save is as JPG...
                Versie Adobe Photoshop: 2014.2.1 20141014.r.257 2014/10/14:23:59:59 CL 987299  x64
                Besturingssysteem: Windows 7 64 bits
                Versie: 6.1 Service Pack 1
                Systeemarchitectuur: Intel CPU-familie:6, Model:10, Stepping:7 met MMX, SSE-integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
                Aantal fysieke processors: 4
                Aantal logische processors: 8
                Snelheid processor: 3410 MHz
                Ingebouwd geheugen: 16301 MB
                Beschikbaar geheugen: 11780 MB
                Hoeveelheid beschikbaar geheugen voor Photoshop: 14586 MB
                Geheugen in gebruik door Photoshop: 70 %
                Afdrukken in 3D met meerdere tonen: Uitgeschakeld.
                Windows 2x UI: Uitgeschakeld.
                Grootlicht: Ingeschakeld.
                Blokgrootte van afbeelding: 1024 kB
                Niveaus voor afbeeldingscache: 4
                Lettertypevoorvertoning: Normaal
                TextComposer: Latijn
                Scherm: 1
                Grenzen: boven= 0, links= 0, onder= 1080, rechts= 1920
                Scherm: 2
                Grenzen: boven= 0, links= 1920, onder= 768, rechts= 3286
                OpenGL-tekenen: Ingeschakeld.
                OpenGL-modus Oude GPU's toestaan: Niet gedetecteerd.
                OpenGL-tekenmodus: Geavanceerd
                OpenGL-modus Normaal toestaan: Waar.
                OpenGL-modus Geavanceerd toestaan: Waar.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                glgpu[0].GLVersion="3.0"
                glgpu[0].GLMemoryMB=1024
                glgpu[0].GLName="GeForce 210/PCIe/SSE2"
                glgpu[0].GLVendor="NVIDIA Corporation"
                glgpu[0].GLVendorID=4318
                glgpu[0].GLDriverVersion="9.18.13.3489"
                glgpu[0].GLRectTextureSize=8192
                glgpu[0].GLRenderer="GeForce 210/PCIe/SSE2"
                glgpu[0].GLRendererID=2661
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                glgpu[0].GLDriverDate="20140208000000.000000-000"
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="3.30 NVIDIA via Cg compiler"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[96]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.1"
                clgpu[0].CLDeviceVersion="1.0 CUDA"
                clgpu[0].CLMemoryMB=1024
                clgpu[0].CLName="GeForce 210"
                clgpu[0].CLVendor="NVIDIA Corporation"
                clgpu[0].CLVendorID=4318
                clgpu[0].CLDriverVersion="334.89"
                clgpu[0].CUDASupported=1
                clgpu[0].CUDAVersion="6.0.1"
                clgpu[0].CLBandwidth=7.83249e+009
                clgpu[0].CLCompute=29.4504
                Type licentie: Abonnement
                Serienummer: 90970305485567695894
                Toepassingsmap: C:\Program Files\Adobe\Adobe Photoshop CC 2014\
                Tijdelijk bestandspad: C:\Users\Robert\AppData\Local\Temp\
                Werkgeheugen van Photoshop heeft asynchrone I/O ingeschakeld
                Werkvolume(s):
                H:\, 111,7 GB, 38,6 GB vrij
                L:\, 111,7 GB, 38,6 GB vrij
                F:\, 111,7 GB, 38,6 GB vrij
                E:\, 931,4 GB, 316,1 GB vrij
                Map met vereiste plug-ins: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Required\Plug-Ins\
                Primaire map voor plug-ins: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Plug-ins\
                Geïnstalleerde componenten:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2014/08/12-23:42:09   79.557478   79.557478
                   adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
                   AdbePM.dll   PatchMatch 2014/09/07-21:07:38   79.558079   79.558079
                   AdobeLinguistic.dll   Adobe Linguisitc Library   8.0.0
                   AdobeOwl.dll   Adobe Owl   5.2.4
                   AdobePDFL.dll   PDFL 2014/08/18-15:13:12   79.512424   79.512424
                   AdobePIP.dll   Adobe Product Improvement Program   7.2.1.3399
                   AdobeXMP.dll   Adobe XMP Core 2014/08/20-09:53:02   79.156797   79.156797
                   AdobeXMPFiles.dll   Adobe XMP Files 2014/08/20-09:53:02   79.156797   79.156797
                   AdobeXMPScript.dll   Adobe XMP Script 2014/08/20-09:53:02   79.156797   79.156797
                   adobe_caps.dll   Adobe CAPS   8,0,0,13
                   AGM.dll   AGM 2014/08/12-23:42:09   79.557478   79.557478
                   ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
                   amtlib.dll   AMTLib (64 Bit)   8.0.0.122212002 BuildVersion: 8.0; BuildDate: Wed Jul 30 2014 15:59:34)   1.000000
                   ARE.dll   ARE 2014/08/12-23:42:09   79.557478   79.557478
                   AXE8SharedExpat.dll   AXE8SharedExpat 2013/12/20-21:40:29   79.551013   79.551013
                   AXEDOMCore.dll   AXEDOMCore 2013/12/20-21:40:29   79.551013   79.551013
                   Bib.dll   BIB 2014/08/12-23:42:09   79.557478   79.557478
                   BIBUtils.dll   BIBUtils 2014/08/12-23:42:09   79.557478   79.557478
                   boost_date_time.dll   photoshopdva   8.0.0
                   boost_signals.dll   photoshopdva   8.0.0
                   boost_system.dll   photoshopdva   8.0.0
                   boost_threads.dll   photoshopdva   8.0.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CIT.dll   Adobe CIT   2.2.6.32411   2.2.6.32411
                   CITThreading.dll   Adobe CITThreading   2.2.6.32411   2.2.6.32411
                   CoolType.dll   CoolType 2014/08/12-23:42:09   79.557478   79.557478
                   dvaaudiodevice.dll   photoshopdva   8.0.0
                   dvacore.dll   photoshopdva   8.0.0
                   dvamarshal.dll   photoshopdva   8.0.0
                   dvamediatypes.dll   photoshopdva   8.0.0
                   dvametadata.dll   photoshopdva   8.0.0
                   dvametadataapi.dll   photoshopdva   8.0.0
                   dvametadataui.dll   photoshopdva   8.0.0
                   dvaplayer.dll   photoshopdva   8.0.0
                   dvatransport.dll   photoshopdva   8.0.0
                   dvaui.dll   photoshopdva   8.0.0
                   dvaunittesting.dll   photoshopdva   8.0.0
                   dynamiclink.dll   photoshopdva   8.0.0
                   ExtendScript.dll   ExtendScript 2014/01/21-23:58:55   79.551519   79.551519
                   icucnv40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
                   icudt40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
                   igestep30.dll   IGES Reader   9.3.0.113
                   imslib.dll   IMSLib DLL   7.0.0.154
                   JP2KLib.dll   JP2KLib 2014/06/28-00:28:27   79.254012   79.254012
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   LogSession.dll   LogSession   7.2.1.3399
                   mediacoreif.dll   photoshopdva   8.0.0
                   MPS.dll   MPS 2014/08/18-23:43:19   79.557676   79.557676
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CC 2014   15.2.1
                   Plugin.dll   Adobe Photoshop CC 2014   15.2.1
                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   5.0.0
                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   5.2.0.52
                   PSArt.dll   Adobe Photoshop CC 2014   15.2.1
                   PSViews.dll   Adobe Photoshop CC 2014   15.2.1
                   SCCore.dll   ScCore 2014/01/21-23:58:55   79.551519   79.551519
                   ScriptUIFlex.dll   ScriptUIFlex 2014/01/20-22:42:05   79.550992   79.550992
                   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   8.0.0.14 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   8.0.0.14
                   VulcanControl.dll   Vulcan Application Control Library   5.0.0.82
                   VulcanMessage5.dll   Vulcan Message Library   5.0.0.82
                   WRServices.dll   WRServices Fri Mar 07 2014 15:33:10   Build 0.20204   0.20204
                   wu3d.dll   U3D Writer   9.3.0.113
                Vereiste plug-ins:
                   3D Studio 15.2.1 (2014.2.1 x001 x003)
                   Adaptief groothoek 15.2.1
                   Andere wolken 15.2.1 (2014.2.1 x001 x003)
                   Arcering 15.2.1
                   Asymmetrisch 15.2.1 (2014.2.1 x001 x003)
                   Basreliëf 15.2.1
                   Bereik 15.2.1 (2014.2.1 x001 x003)
                   BMP 15.2.1
                   Bol 15.2.1
                   Camera Raw 8.6
                   Camera Raw-filter 8.6
                   Chroom 15.2.1
                   Cineon 15.2.1 (2014.2.1 x001 x003)
                   Collada 15.2.1 (2014.2.1 x001 x003)
                   CompuServe GIF 15.2.1
                   Conté crayon 15.2.1
                   Craquelure 15.2.1
                   De-Interlace 15.2.1
                   Dicom 15.2.1
                   Donkere lijnen 15.2.1
                   Droog penseel 15.2.1
                   Eazel Acquire 15.2.1 (2014.2.1 x001 x003)
                   Entropie 15.2.1 (2014.2.1 x001 x003)
                   FastCore Routines 15.2.1 (2014.2.1 x001 x003)
                   Filigraan 15.2.1
                   Filmkorrel 15.2.1
                   Filter Figuurpakket 15.2.1 (2014.2.1 x001 x003)
                   Filter Foto's uitsnijden en rechttrekken 15.2.1
                   Filtergalerie 15.2.1
                   Flash 3D 15.2.1 (2014.2.1 x001 x003)
                   Fotokopie 15.2.1
                   Foto's uitsnijden en rechttrekken 15.2.1 (2014.2.1 x001 x003)
                   Fresco 15.2.1
                   Geaccentueerde randen 15.2.1
                   Gebrandschilderd glas 15.2.1
                   Geef diepte 15.2.1
                   Gemiddeld 15.2.1 (2014.2.1 x001 x003)
                   Gemiddelde 15.2.1 (2014.2.1 x001 x003)
                   Gescheurde randen 15.2.1
                   Gips 15.2.1
                   Glas 15.2.1
                   Gloed onscherp 15.2.1
                   Golf 15.2.1
                   Google Earth 4 15.2.1 (2014.2.1 x001 x003)
                   Grafische pen 15.2.1
                   Halftoonraster 15.2.1
                   HDRMergeUI 15.2.1
                   Hoeklijn 15.2.1
                   Houtskool 15.2.1
                   HSB/HSL 15.2.1
                   IFF-formaat 15.2.1
                   IGES 15.2.1 (2014.2.1 x001 x003)
                   Inktomtrek 15.2.1
                   JPEG 2000 15.2.1
                   Kleur halftoon 15.2.1
                   Kleur-opzoektabellen exporteren NO VERSION
                   Kleurpotlood 15.2.1
                   Klodder 15.2.1
                   Kneep 15.2.1
                   Knipsel 15.2.1
                   Korrel 15.2.1
                   Krijt en houtskool 15.2.1
                   Kristal 15.2.1
                   Kronkel 15.2.1
                   Lappendeken 15.2.1
                   Lenscorrectie 15.2.1
                   Matlab Operation 15.2.1 (2014.2.1 x001 x003)
                   Maximaal 15.2.1 (2014.2.1 x001 x003)
                   Mediaan 15.2.1 (2014.2.1 x001 x003)
                   Metingskern 15.2.1 (2014.2.1 x001 x003)
                   Mezzotint 15.2.1
                   Minimaal 15.2.1 (2014.2.1 x001 x003)
                   MMXCore-routines 15.2.1 (2014.2.1 x001 x003)
                   Mozaïektegels 15.2.1
                   Neon gloed 15.2.1
                   NTSC-kleuren 15.2.1 (2014.2.1 x001 x003)
                   Oceaanrimpel 15.2.1
                   Ondersteuning van meerdere processors 15.2.1 (2014.2.1 x001 x003)
                   OpenEXR 15.2.1
                   Oplichtende rand 15.2.1
                   Opslaan voor web 15.2.1
                   Optelling 15.2.1 (2014.2.1 x001 x003)
                   Paden naar Illustrator 15.2.1
                   Paletmes 15.2.1
                   PCX 15.2.1 (2014.2.1 x001 x003)
                   Perspectiefpunt 15.2.1
                   Photoshop 3D-engine 15.2.1 (2014.2.1 x001 x003)
                   Photoshop Touch 14.0
                   Pixar 15.2.1 (2014.2.1 x001 x003)
                   Plastic 15.2.1
                   PLY 15.2.1 (2014.2.1 x001 x003)
                   PNG 15.2.1
                   Pointilleren 15.2.1
                   Poolcoördinaten 15.2.1
                   Portable Bit Map 15.2.1 (2014.2.1 x001 x003)
                   Posterranden 15.2.1
                   Postpapier 15.2.1
                   PRC 15.2.1 (2014.2.1 x001 x003)
                   Radiaal vaag 15.2.1
                   Radiance 15.2.1 (2014.2.1 x001 x003)
                   Raster Kleur opzoeken renderen NO VERSION
                   Rimpel 15.2.1
                   Ruw pastel 15.2.1
                   Schokreductie 15.2.1
                   Schuin 15.2.1
                   Scriptondersteuning 15.2.1
                   Slim vervagen 15.2.1
                   Solariseren 15.2.1 (2014.2.1 x001 x003)
                   Spetters 15.2.1
                   Spons 15.2.1
                   Sproeilijn 15.2.1
                   Standaardafwijking 15.2.1 (2014.2.1 x001 x003)
                   Stempel 15.2.1
                   STL 15.2.1 (2014.2.1 x001 x003)
                   Structuurmaker 15.2.1
                   Sumi-e 15.2.1
                   Targa 15.2.1
                   Tegels 15.2.1
                   U3D 15.2.1 (2014.2.1 x001 x003)
                   Uitvloeien 15.2.1
                   Vage lens 15.2.1
                   Variantie 15.2.1 (2014.2.1 x001 x003)
                   Verplaatsen 15.2.1
                   Vezels 15.2.1
                   Virtual Reality Modeling Language | VRML 15.2.1 (2014.2.1 x001 x003)
                   Vlek 15.2.1
                   Voorbewerking 15.2.1
                   Watermerk insluiten 4.0
                   Watermerk lezen 4.0
                   Waterpapier 15.2.1
                   Waterverf 15.2.1
                   Wavefront|OBJ 15.2.1 (2014.2.1 x001 x003)
                   Welving 15.2.1 (2014.2.1 x001 x003)
                   WIA-ondersteuning 15.2.1 (2014.2.1 x001 x003)
                   Wind 15.2.1
                   Wireless Bitmap 15.2.1 (2014.2.1 x001 x003)
                   Wolken 15.2.1 (2014.2.1 x001 x003)
                   ZigZag 15.2.1
                   Zon 15.2.1
                Optionele plug-ins en plug-ins van derden: GEEN
                Plug-ins die niet konden worden geladen: GEEN
                Flash:
                   Bibliotheken
                   Adobe Color-thema's
                Geïnstalleerde TWAIN-apparaten: GEEN
                • 6. Re: PS removes selections where there are none
                  Look like there is a newer driver available with a release date of July 29, 2014 your has a Feb. 8, 2014. The first thing I would try is updating the display driver it looks like the images is not displaying correctly. Drivers | GeForce
