3 Replies Latest reply on Oct 23, 2014 4:37 PM by A.T. Romano
    Graver un disque Bluray
    Odul
      Sous Windows 7
      Graveur LG
      Adobe Premiere Elements 13
      Je ne parviens pas à graver un Bluray. Le programme affiche "Media absent" alors qu'il reconnait l'emplacement de mon graveur.
      Que faire ?
        • 1. Re: Graver un disque Bluray
          A.T. Romano Level 7
          odul
          Can you produce an ISO Image (25 or 50 GB) using Premiere Elements 13 Publish+Share/Disc/Blu-ray? If so,
          you could produce your Premiere Elements 13 Blu-ray disc format on Blu-ray disc by taking the ISO Image into ImgBurn.
          How to write an image file to a disc using ImgBurn - Guides - ImgBurn Support Forum
          First hand instructions can be supplied if needed.
          ISO Image is new to Premiere Elements burn to choices. And, I am still working through some finer points
          involved in the process from Premiere Elements ISO Image to a ImgBurn final Blu-ray disc product.
          What brand/type Blu-ray disc are you using?
          We will be watching for your details.
          Thank you.
          ATR
          • 2. Re: Graver un disque Bluray
            Odul Level 1
            Thank you Romano. I have tried two different brands : Sony and Philips. I know I can record an ISO image and burn it. But I would have liked to burn my film immediately with Adobe Premiere.
            • 3. Re: Graver un disque Bluray
              A.T. Romano Level 7
              Odul
              Thank you for the reply.
              Since you have had Premiere Elements 13, have you ever gotten the Status field of the burn dialog to show Ready, instead of Media
              not Present for your burn to Blu-ray? If you insert a DVD disc for DVD or AVCHD, is the DVD disc recognized?
              These Media Not Present in burn to in the Premiere Elements Publish+Share/Disc/ area are particularly frustrating.
              There is no one fix for the problem.
              1. The change disc approach has not worked for you.
              2. Have you verified that your LG burner has the latest firmware updates and related updates?
              3. Sometimes it is the case where the following will resolve the matter -
              a. Deleting the Adobe Premiere Elements Prefs file or, if that does not work, the whole 13.0 Folder in which it exists.
              Local Disk C
              Users
              Owner
              AppData
              Roaming
              Adobe
              Premiere Elements
              13.0
              and in the 13.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then you delete
              the whole 13.0 Folder in which the Adobe Premiere Elements Prefs file exists. Be sure to be working with Folder Option
              Show Hidden Files, Folders, and Drives active so that you can see the complete path cited.
              4. Then there is the more extreme approach of uninstall, inreinstall according to the following scheme.
              Make sure your have program installation files or installation disc and purchased serial number before you consider this.
              a. Deactivate the program from an opened project's Help Menu/Sign Out. Close out of there.
              b. Uninstall the program using the regular Control Panel way
              c. Do a free ccleaner run through (regular cleaner and registry cleaner parts)
              https://www.piriform.com/ccleaner/download
              d. Reinstall the program with the antivirus and firewall(s) disabled.
              Please review and consider and determine if any of the above works for you. We will think about this some more.
              Thank you.
              ATR
