2 Replies Latest reply on Oct 22, 2014 8:16 AM by Ciccio Pasticcio
    Free Trasform applied to selections leaves grey lines on the edges (when Interpolation is set to Bicubic Smoother/Sharper/Automatic)
    Ciccio Pasticcio Level 1
      first of all, I must thank you for this great application, I love Photoshop CC 2014.
      Here's the problem: whenever I make a selection with the Rectangular Marquee Tool and I try to scale it to the right for example, with Ctrl+T,
      I find a grey line on the opposite side (left in this case) after confirming the transformation and deselecting. I'll show you what I mean:
      I want to make clear that I didn't move the selection, just scaled it on the right and deselected it. Also, as I've already pointed out, this
      doesn't happen with other Interpolation options. Question: is this really how the math behind Bicubic Smoother and Sharper (Automatic
      must be either of those) is supposed to work? If not, I'd so like to use the best algorithm when I scale selections without having to make
      further adjustments to the outcome of the transformation as well. Thanks.
