1. Re: unable to save designer pdf after editing.
Dave Merchant Oct 23, 2014 3:03 AM (in response to elsabes)Make sure you don't have the folder open in Windows Explorer with the 'preview' area enabled.
2. Re: unable to save designer pdf after editing.
elsabes Oct 23, 2014 3:06 AM (in response to Dave Merchant)I use chrome?
3. Re: unable to save designer pdf after editing.
elsabes Oct 23, 2014 3:16 AM (in response to Dave Merchant)Sorry, need to be more specific, I did compatibility settings in explorer because the completed pdf form is auto generated and populated from a web based application called Collaborator and the preferred browser is Explorer. The problem is in Designer es4, I insert encryption in the form on the submit event and need to edit and review all the time. To save time I save and open the form in adobe reader XI because the pdf viewer in es4 is too slow with bulky scripts.
4. Re: unable to save designer pdf after editing.
Dave Merchant Oct 23, 2014 3:50 AM (in response to elsabes)I'm talking about Windows Explorer, not Internet Explorer.
If you're opening a file from inside a browser window, make sure you've saved a copy to a sensible place on your local hard drive before editing it. You can't save back to the server.
5. Re: unable to save designer pdf after editing.
elsabes Oct 23, 2014 4:19 AM (in response to Dave Merchant)I mean saving from designer to my local files, client side before the pdf is uploaded on server.
6. Re: unable to save designer pdf after editing.
elsabes Oct 23, 2014 4:40 AM (in response to Dave Merchant)Thanks for your suggestions, i will close explorer before saving and see what happens
7. Re: unable to save designer pdf after editing.
elsabes Oct 23, 2014 5:09 AM (in response to Dave Merchant)Such a simple thing creating so many problems. You were right, the preview window was the problem, so thanks again for responding! You learn something new every day!
