1. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
Jon Fritz II Oct 23, 2014 9:12 AM (in response to WolfShade)What all have you tried (so we don't offer up stale ideas and waste your time)?
Clear program cache, preference reset, cleaner tool reinstall, etc?
2. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
WolfShade Oct 23, 2014 9:41 AM (in response to Jon Fritz II)I've looked for extensions (there aren't any) and I've tried looking for "WinFileCache*****.dat" and "FileCache*****.dat" to delete them, but cannot seem to find them, anywhere, so can't delete them. Those are the two most common suggestions that I've found, so far.
^_^
3. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
Jon Fritz II Oct 23, 2014 10:14 AM (in response to WolfShade)Ah, you need to turn on your OS's hidden files to get to the right place for those steps.
Control Panels > Folder Options > Turn on the radio button on "Show hidden files, folders and drives"
Then you can try the cache, config steps.
4. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
WolfShade Oct 23, 2014 10:26 AM (in response to Jon Fritz II)That's already checked on.
I went into C: drive via Windows Explorer and used the search bar, looking for "filecache*.dat" and didn't find any that were for DreamWeaver.
V/r,
^_^
5. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
Jon Fritz II Oct 23, 2014 10:49 AM (in response to WolfShade)WolfShade wrote:
V/r,
^_^
You need to browse to it, the Windows search function won't show you hidden files and folders without additional shenanigans.
Also, the actual file is WinFileCache-(random numbers and letters).dat
Using "filecache*.dat" as the search term will come up empty handed, at least it did when I tested it from the folder with the WinFileCache*******.dat file in it...
6. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
WolfShade Oct 23, 2014 11:32 AM (in response to Jon Fritz II)Do you know the folder that the .dat file is in? I can just use Windows Explorer to navigate to the folder, directly.
^_^
7. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
Jon Fritz II Oct 23, 2014 12:11 PM (in response to WolfShade)-your hard drive letter- > Users > -your user name- > AppData > Roaming > Adobe > Dreamweaver -version #- > -your language- > Configuration
Deleting a corrupted cache file
8. Re: Yet another discussion about "dwscriptsExtData.js" (sorry)
WolfShade Oct 23, 2014 12:30 PM (in response to Jon Fritz II)AH! Thanks! Found the little bugger and kicked it to the Recycle Bin.
I'll run with this for a bit, and let you know if it worked.
Thanks!
^_^
