2 Replies Latest reply on Oct 25, 2014 9:02 AM by Bill Gehrke
    Premiere Pro Exported video dont work
    Veir95
      Hello, so i've got problem with Adobe Premiere Pro CS6, when  export Full HD video (35minutes)it takes like 1.5h to be done but thats not the main problem. Whb its finally exported i go to my exported video folder and yea its here with 8gb or weight i open it and... Poof! its not opening i even get errors that its corrupted or something like that, when i check video informationsnthe resolution, fps and other stuff is blank, there is no information about video at all
      My Export settings
      Format H.264
      Preset Custom
      1920x1080
      VBR 1 Pasa
      Min target 32 MB/s Max 40 MB/s
      Audio 320kb/s
      48kHZ
      video is 34 minutes long
      Muliplexer MP4
      FPS 29.97 (oryginal video fps is 50)
      My PC
      Amd Phenom II 945 4x 3.2GHz or 3.0GHz i dont remember
      GPU: Asus GeForce GTX750 OC 1GB
      Ram: kingston 3gb
      and some ****** hdd
      Guys help me why my exported video dont open
        • 1. Re: Premiere Pro Exported video dont work
          Veir95 Level 1
          EDIT: I changed multiplexer from 3gp to mp4 and now its working
          • 2. Re: Premiere Pro Exported video dont work
            Bill Gehrke Most Valuable Participant
            Glad that you made it work.
            About the time required to export, do you have the GPU enabled to assist with the Mercury Playback Engine (MPE) exporting?  Look at Project/Project Settings/General is Video Rendering and Playback option grayed out?
            If you do not have the option there you will have to find the Adobe Premiere file "cuda_supported_cards.txt" file and add your "GeForce GTX 750" card to the list and after restarting Premiere you should see the option.
            Using the GPU instead of the CPU only should cut your export time significantly.
