2 Replies Latest reply on Mar 26, 2007 10:29 AM by SafariTECH
    Flash Grid in Director
    SafariTECH Level 1
      In the past we have only created software for Windows using Director, so we had a ton of options for grid controls.
      Now, we have been asked to port one software to Mac as well. This reduced our choices for grids ( that look and work decently in both OS) to pretty much the Flash Grid control available in Director.
      It looks pretty good and it works pretty well, but one thing that happens all the time is the columns are always way too small (width) and the text in them gets cramped or wrapped. The user always has to manually drag the column widths so they can read them.
      If I search in the help files I can find nothing about the Flash grid control ... are there Lingo commands that will allow me to define the column widths??
        • 1. Re: Flash Grid in Director
          Charles Parcell Level 1
          Well, to be clear, the DataGrid component did not come with Director 2004. A developer can copy the SWC file over and have it available within Director.
          I can tell you that any of the Flash components which were not included in the release of Director 2004, were left out on purpose. The reason was because there was some degree of incompatibility at release. Specific what that is? I don't know the specific details.
          This does not mean that the DataGrid will not function in your project. It could simply mean that data binding doesn't work. Test Test Test is my main suggestion.
          As for using the DataGrid... You have access to all the exposed methods and properties to any component you add to Director. Thus you should be able to uses anything found here....
          http://livedocs.adobe.com/flash/8/main/wwhelp/wwhimpl/js/html/wwhelp.htm?href=Part4_ASLR2. html
          • 2. Re: Flash Grid in Director
            SafariTECH Level 1
            Thanks Charles,
            The Grid Compnent is actually located in Director immediately after install ( I never tranferred it) ... but its not part of the Flash Components menu/toolbar ... just the Code Library.
            I am using it with INM's VisionDB which recommends the Grid for Director, although it took me a few minutes to figure out where it was located.
            Anyways, that aside, I figured out where to adjust their coding (INMs) to affect the column widths better ... problem was they were using the column title as the width catalyst rather than the longest entry in the column.
            All-in-all it works really well and so far there are no issues with the Flash Grid component in Director MX 2004 10.1 so at least I have a good option for cross platform grids now.
