3 Replies Latest reply on Oct 23, 2014 5:59 PM by A.T. Romano
    Saved MP4 video is 4 times larger than original -only removed 3 minutes of video
    kjkroha
      Did not add music, extra tracks, etc- only cut off the first three minutes.  Original file was 891 MB, saved video 3.1GB.
      I need to save it as an mp4.
      Settings, suggestions MOST appreciated!
      Thanks!
        • 1. Re: Saved MP4 video is 4 times larger than original -only removed 3 minutes of video
          A.T. Romano Level 7
          kjkronha
          What version of Premiere Elements and on what computer operating system is it running?
          Most likely a mismatch of original bitrate and compression with the selections that you made in the export settings of your project.
          But, the answers will be in the details, so more details please.
          Original
          Video and Audio compression
          Frame size and Frame rate
          interlaced or progressive
          file extension
          pixel aspect ratio
          bitrate
          Export
          Assuming Premiere Elements 11, 12, or 13
          Publish_Share
          Computer
          and then what
          If AVCHD, what did you select for Presets?
          And, did you go with the default settings for the Preset or customize the export setting under the
          Advanced Button/Video Tab and Audio Tab of the preset? What were your export settings?
          Please review and consider and then we can sort out what needs to be done. Do you have any
          requirements given to you for this project as to file size.
          Looking forward to your follow up.
          Thank you.
          ATR
          • 3. Re: Saved MP4 video is 4 times larger than original -only removed 3 minutes of video
            A.T. Romano Level 7
            kjkroha
            Thanks for the update on the file size of the original.
            Interesting.
            Nonetheless what are the answers for all the questions that I asked so that I can get a clearer perspective
            of what might have happened to take an import of 891 KB to 3.1 GB.
            It would be interesting to know what a video audio properties readout program would show for the bitrate of
            the 3.1 GB file. Since you have not yet posted the Premiere Elements version and computer operating system
            information yet, I will guess you have Windows and will post the link for MediaInfo Windows for use for video
            properties readout.
            http://sourceforge.net/projects/mediainfo/
            But, you should be able to get that information by looking at the bitrate settings in the export settings that you used for your Premiere Elements export.
            When you mentioned KB and MB, I am assuming that you mean kilobytes (KB) and megabytes (MB) and not
            kilobits (kb or Kb) and megabits (Mb).
            Thanks for the follow ups.
            ATR
