9 Replies Latest reply on Mar 22, 2007 10:52 AM by Newsgroup_User
    accessing shared object
    Level 7
      If in an SWF file I create a shared object like this
      var so:SharedObject = SharedObject.getLocal("name");
      and sore some value in it
      so.data.my_value="my_value"
      Then I load another swf into this swf, can I retreive my_value?
      I.e. can I access so from the loaded file?
        • 1. Re: accessing shared object
          Level 7
          aa,
          > and sore some value in it so.data.my_value="my_value"
          Right ...
          > my_value? I.e. can I access so from the loaded file?
          Same way. The SharedObject.getLocal() method either gets the shared
          object referenced or creates a new one. If the shared object already
          exists -- because you've already created one -- then you would refer to that
          "so" variable (your instance of the SharedObject class) and reference its
          data property to access that property -- just as you've done to set its
          value.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: accessing shared object
            what's the point of using a sharedobject in a swf that's still open and still contains "my_value"?
            • 3. Re: accessing shared object
              Level 7
              I posted this question because ut did not work.
              Tracing so.data.my_value from the file loaded returned undefined.
              I know that each swg created its own shared object, and though it might have
              the same name, it is stored in a different location and one swf cannot
              access shared object.
              I hoped that the loaded swf is executed in the context of the loading SWF
              and therefore can access that shared object. If this assumption is correct,
              how shall I do it?
              "David Stiller" <stiller@quip-remove-.net> wrote in message
              news:etu68s$p4s$1@forums.macromedia.com...
              > aa,
              > Right ...
              that
              > value.
              > David Stiller
              • 4. Re: accessing shared object
                Level 7
                aa,
                > undefined.
                Have you done any troubleshooting? Can you create and then access a
                shared object without an external SWF? Is it just the external SWF that
                causes the problem?
                > and though it might have the same name, it is stored in
                > a different location and one swf cannot access shared
                > object.
                This is possibly new information. ;) Are you saying the external SWF
                is being loaded from another domain? If so, you'll want to check into the
                optional localPath parameter in the static getLocal() method.
                David Stiller
                • 5. Re: accessing shared object
                  Level 7
                  news:etu9sd$fm$1@forums.macromedia.com...
                  > aa,
                  > causes the problem?
                  In my context the shared object has to be created by the external SWF and to
                  be accessed by the internal one.
                  The external SWF created SO and traces values stored in it correctly. The
                  internal SWF returnes undefined
                  > > object.
                  I wish I was wrong for it will solve my ptoblem. Are you saying that one SWF
                  can access a SO created by another SWF?
                  They are in the same folder on my local disk.
                  >If so, you'll want to check into the optional localPath parameter in the
                  As I learned from this NG, the local path does not accept syntax like ../
                  which in HTML allows to go to the parent directory.
                  • 6. Re: accessing shared object
                    Level 7
                    aa,
                    > that one SWF can access a SO created by another SWF?
                    Yes.
                    > like ../ which in HTML allows to go to the parent directory.
                    Flash certainly understands paths ../, /, and the like. I use them all
                    the time. Those are called relative paths, and the only tricky thing about
                    that is that they depend on the calling SWf's point of view in the
                    arrangement of files and folders.
                    But the localPath parameter in this case has its own special syntax, as
                    specified in the documentation. Here's a quick test I did in two SWFs named
                    so-a.swf and so-b.swf.
                    // so-a code:
                    var so:SharedObject = SharedObject.getLocal("aaTest", "/");
                    if (so.data.myVar) {
                    trace("a: " + so.data.myVar);
                    } else {
                    so.data.myVar = "apples"
                    loadMovieNum("so-b.swf", 1);
                    // so-b code:
                    trace("b: " + so.data.myVar);
                    Notice the opational localPath parameter used by both. In the first
                    SWF, the SharedObject.getLocal() method is used to retrieve a local shared
                    object named aaTest (named after you). If such a local shared object does
                    not exist, SWF A creates it.
                    If the SharedObject instance's data property contains a myVar property,
                    SWF A traces its value. If not, it sets that propert's value to "apples."
                    Then it loads SWF B.
                    SWF B does very nearly the same thing. When I test these SWF, both A
                    and B trace their respective recognition of the value of myVar.
                    David Stiller
                    • 7. Re: accessing shared object
                      Level 7
                      It works indeed if I run the first file and then the second one.
                      If I load the second into the first, it does not.
                      trace() does not seem to return anything even when I removed conditional if
                      in your code - ???
                      news:etucth$4e6$1@forums.macromedia.com...
                      > aa,
                      > Yes.
                      all
                      about
                      as
                      named
                      > // so-a code:
                      > } else {
                      > // so-b code:
                      property,
                      > David Stiller
                      • 8. Re: accessing shared object
                        Level 7
                        aa,
                        That's right. Isn't that the idea? You wanted to know if two different
                        SWFs could access the same SharedObject. Maybe I didn't understand?
                        That makes sense, because the second one does not set a value to
                        myVar -- as you can see, it only reports on an existing value (if one
                        exists).
                        > conditional if in your code - ???
                        Which if statement?
                        David Stiller
                        • 9. Re: accessing shared object
                          Level 7
                          this has been sorted out by re-starting Windows
                          So the idea works, now I'll try to use it for my needs. Thank you
