1. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 26, 2014 10:23 PM (in response to varunflash)No one has idea about this?
2. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
poltergeist_ Oct 27, 2014 2:43 AM (in response to varunflash)I remember it was a struggle to get it working for myself. You use both the app certificate and the push certificate for production when bundling? Also there is no support for iOS 8 in Air 4, but I am not sure if that results in an error while installing. Try latest Air SDK to be sure.
3. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 27, 2014 2:54 AM (in response to poltergeist_)Thanks for replying, there is no response for this question from anywhere.
1. Yes I have used production certificates and profile. Even tried uploading the build to testflight but from there the error is "problem downloading application this time" and I kept hitting retry but did not worked. App icon turns dark and keeps saying installing...
2. Let me try with latest AIR SDK - 15.0.0.302 - then I will try with testflight and iTunes again.
4. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 27, 2014 3:57 AM (in response to varunflash)It is not installing even with latest SDK and I also tried generating profile again and published the app again but not working. Development version is working fine. I don't know what is the reason.
5. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 28, 2014 5:29 AM (in response to varunflash)It took more than 7-8 day to figure out. There was a confusion between p12 certificates, I changed the certificate to the one for push notification, but the push notification one is only required to generate pem file, for signing app it is not required. Just changed the certificate to the last certificate that was used to publish for production and app got installed. The solution came up when I tried to upload the build using application loader and there was an error for the certificate signing. It is solved relaxed
But game is not over yet one more error came now it says publish app with latest version of Xcode, I am building it with Flash and it say about Xcode. Hopefully this gets resolved soon.
6. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 28, 2014 5:32 AM (in response to varunflash)Any idea on this:
ERROR ITMS-9000: "Invalid Segment Alignment. This app does not have proper segment alignment and should be rebuilt with the latest version of Xcode. Please contact Developer Technical Support if you need further assistance."
7. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
Jan-F-W Oct 28, 2014 5:48 AM (in response to varunflash)As poltergeist_ mentioned above iOS 8 does not support apps build with AIR 4. You need to build your app with the latest version of AIR to be able to run it on iOS 8.
8. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 29, 2014 12:34 AM (in response to Jan-F-W)Changing SDK to 15.0.0.302 solved the problem, app successfully submitted to appstore.
9. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 29, 2014 12:54 AM (in response to varunflash)Any idea how to install app on iPad with iOs 8.1 using Flash CS6? Even latest AIR SDK is not able to install the app the reason that looks like is, when you check iPad Settings->General -> there is no option to view profiles installed, it mean new version of iOs does not allow to install provisioning profiles, so apps can not be installed.
10. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
Colin Holgate Oct 29, 2014 5:12 AM (in response to varunflash)I have not been able to build to my iPad for a while, though I haven't yet tried with build 349. I use Xcode to put apps onto it for testing.
11. Re: Problem installing Adhoc version to iPhone and iPad - Development Environment - Adobe Flash CS6
varunflash Oct 29, 2014 5:51 AM (in response to Colin Holgate)I tried testflight and it installed profile to iPad now development version is installing on ipad even through iTune, but still not successful direct from Flash CS6. The problem is with installing profile on iOs 8.1, testflight did it and app is installing now. I am using Flash CS6 and SDK 15.0.0.302
