15 Replies Latest reply on Oct 27, 2014 10:23 AM by Heliodon
    Map Module LR 5.6 after Upgrade for iMac Yosemite
    Border Allan
      Hi
      This is my first request for help on the forum and hope you can help please
      Using an iMac on mavericks  and LR 5.5 map module worked fine
      Upgraded to Yosemite map module is not working correctly some time-outs says maps is off line other times loads intermittent parts of map
      Tried clean install of the mac and CC with LR 5.6 same problem
      Some site suggest this is a flash issue this does not seem to be the case
      Connection via ethernet is my norm but tried wifi same result
      Issue only seems to be LR no other program is affected
      Using Sky modem
      My inbulit fire wall is off and its a home network
      The LR app for iPad works ok and the web module works fine
      Any idea what on earth i am missing please prior to the Yosemite upgrade i did a google search and adobe suggested no issues had been found when used with CC
      Thank you
      Allan
