1. Re: hide folios with not entitlements
Neil Enns - Adobe Oct 24, 2014 9:20 AM (in response to mediacross)I'd ignore that line in the documentation. Call updateLibrary() after direct entitlement sign in or sign out and you will be fine. That flow (updateLibrary() after sign in/sign out) is exactly what we do in the native library.
Neil
2. Re: hide folios with not entitlements
paolo bill Oct 24, 2014 10:16 AM (in response to Neil Enns - Adobe)Actually if I consol.log the folios entitlementType on the updateLibrary handler it's still the same as before I login or out. But if I look at it later it gets updated as it should.
I'm Using api v1. I asked to be updated to v2.
I Don't know if it makes any difference.
I Know there is an updateSignal on the folio. But that doesn't do it for me
3. Re: hide folios with not entitlements
Neil Enns - Adobe Oct 24, 2014 10:49 AM (in response to paolo bill)The API version used for your entitlement server doesn’t make a difference. The flow you are trying in your custom library is correct, it is the same flow we use in the native application.
If it isn’t working as you expect you should open a support request with our enterprise support line. Sign in to http://digitalpublishing.acrobat.com/ and look in the bottom middle of the screen for contact information.
Neil
