1. Re: Could not complete your request because of a disk error.
Chris Cox Oct 24, 2014 6:36 PM (in response to GreggLC)Either your ACR plugin is corrupt on disk, or you have a serious problem with your disk that is causing errors.
2. Re: Could not complete your request because of a disk error.
GreggLC Oct 24, 2014 6:41 PM (in response to Chris Cox)I have just installed new hard drive and re installed CC and now this comes up. how do i remove car plugin and reinstall?
3. Re: Could not complete your request because of a disk error.
Warunicorn Oct 24, 2014 6:49 PM (in response to GreggLC)Is it every image you try to open?
4. Re: Could not complete your request because of a disk error.
GreggLC Oct 24, 2014 6:51 PM (in response to Warunicorn)All NEF files and if i try open as a filter from PS, eevn JPG
5. Re: Could not complete your request because of a disk error.
Warunicorn Oct 24, 2014 7:03 PM (in response to GreggLC)I would try uninstalling/reinstalling. If that doesn't work, it may be a case of data corruption as Chris mentioned. (Do you have those NEF files backed up?)
6. Re: Could not complete your request because of a disk error.
GreggLC Oct 24, 2014 7:08 PM (in response to Warunicorn)yes i do, even when trying from external drive it does the same. reinstalled. No difference
7. Re: Could not complete your request because of a disk error.
Warunicorn Oct 24, 2014 7:22 PM (in response to GreggLC)Did you try checking your scratch disk (as well as performance) settings?
Is it maybe a permissions issue? Do you have administrative access to Photoshop?
8. Re: Could not complete your request because of a disk error.
GreggLC Oct 24, 2014 7:47 PM (in response to Warunicorn)yes, done all of that
9. Re: Could not complete your request because of a disk error.
FelipeML Dec 1, 2014 8:04 AM (in response to GreggLC)GregLC, I have the exakt same problem. Did you find any solution? I have tried everything. :-/
10. Re: Could not complete your request because of a disk error.
GreggLC Dec 1, 2014 8:23 AM (in response to FelipeML)yes, i got rid of yosemite and went back to Mavericks now everything is good
11. Re: Could not complete your request because of a disk error.
FelipeML Dec 1, 2014 8:35 AM (in response to GreggLC)GreggLC thnx for the answer, Im considering that solution as well...
Freakin Yosemite....
