0 Replies Latest reply on Oct 25, 2014 4:44 PM by austinsometin
    Embedding External XML
    austinsometin Level 1
      Hey guys. Based of the ModestMap API example for flex, I want to be able to embed an external XML file instead of directly populating the xml tags on the main app. i have tried different approaches, the markers are not showing up. thanks in advance!
      here is the sample code from modestmap
      <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/halo"
        minWidth="
      1024" minHeight="768" creationComplete="init()" viewSourceURL="srcview/index.html" xmlns:mx1="library://ns.adobe.com/flex/mx">
         <fx:Script>
        <![CDATA[
         import mx.core.UIComponent;
         import com.modestmaps.TweenMap
         import com.modestmaps.mapproviders.OpenStreetMapProvider;
         import com.modestmaps.mapproviders.yahoo.YahooHybridMapProvider;
         import com.modestmaps.geo.Location;
         import com.modestmaps.extras.ZoomSlider;
         import com.modestmaps.extras.HandCursor
         import com.custom.PointMarker;
         import com.custom.infoPanel;
         []private var _map:TweenMap
         private var _mapUI:UIComponent;
         []private var _initialLat:Number = 40.668903;
         []private var _initialLong:Number = -111.680145;
         []private var _initialZoom:Number = 6;
         private var _mouseWheelZoomCenter:Location;
         private var _mouseWheelZoom:int;
         private var resortMarker:PointMarker
         private var _panel:infoPanel;
         [("img/marker.png")]
         protected var MarkerImage:Class;
         private var srcXML:XML =
         <root>
        <location>
        <name>Alta Ski Resort</name>
        <lat>40.588063</lat>
        <long>-111.637659</long>
        <description>Home of the Greatest Snow on Earth</description>
        </location>
        <location>
        <name>Crested Butte Resort</name>
        <lat>38.899932</lat>
        <long>-106.964249</long>
        <description>Amazing skiing with small town charm</description>
        </location>
        </root>
         private function init():void
         _map = new TweenMap(mappanel.width, mappanel.height, true, new OpenStreetMapProvider())
         _map.setCenterZoom(new Location(_initialLat, _initialLong), _initialZoom);
         mapCore();
         private function mapCore():void
         _map.addEventListener(MouseEvent.MOUSE_WHEEL, mouseWheelHandler)
         _mapUI = new UIComponent();
         _mapUI.addChild(_map)
         var zoomslider:ZoomSlider = new ZoomSlider(_map);
         zoomslider.x = mappanel.width - zoomslider.width*2;
         zoomslider.y = 30;
         _mapUI.addChild(zoomslider)
         var handcursor:HandCursor = new HandCursor(_map);
         _mapUI.addChild(handcursor);
         mappanel.addElement(_mapUI);
         _panel = new infoPanel();
         _panel.containerHeight = mappanel.height;
         _panel.containerWidth = mappanel.width;
         mappanel.addElement(_panel)
         addMarkers();
         private function addMarkers():void
         for each (var resort:XML in srcXML.location){
         resortMarker = new PointMarker()
         var markerImage:Bitmap = new MarkerImage() as Bitmap;
         markerImage.x = -markerImage.width/2
         markerImage.y = -markerImage.height/2
         resortMarker.addChild(markerImage);
         resortMarker.resortName = resort.name;
         resortMarker.resortDesc = resort.description;
         resortMarker.addEventListener(MouseEvent.CLICK, handleMouseClick)
         _map.putMarker(new Location(resort.lat, resort.long), resortMarker)
         private function mouseWheelHandler(e:MouseEvent):void {
         if (e.delta < 0) {
         _map.zoomOut();
         else if (e.delta > 0) {
         _map.zoomIn();
         _mouseWheelZoomCenter = _map.getCenter();
         _mouseWheelZoom = _map.getZoom();
         private function handleChangeProvider(event:Event):void
         mappanel.removeAllElements();
         if(event.target.label == "Virtual Earth")
         _map = new TweenMap(mappanel.width, mappanel.height, true, new YahooHybridMapProvider());
         else
         _map = new TweenMap(mappanel.width, mappanel.height, true, new OpenStreetMapProvider());
         if(_mouseWheelZoomCenter != null && _mouseWheelZoom > 0)
         _map.setCenterZoom(_mouseWheelZoomCenter, _mouseWheelZoom)
         else
         mapCore();
         private function handleMouseClick(event:MouseEvent):void
         _panel.ptitle = event.target.resortName;
         _panel.pdesc = event.target.resortDesc;
         </fx:Script>
         <s:BorderContainer id="mappanel" width="100%" height="97%"/>
         <mx1:HBox width="100%" horizontalAlign="right">
         <mx1:Button label="Open Street Map" click="handleChangeProvider(event)"/>
         <mx1:Button label="Virtual Earth" click="handleChangeProvider(event)"/>
         </mx1:HBox>
      </s:Application>
      ///////////////////////////////////////I tried for the external XMl//////////////////////////////
      [Embed(source="data.xml", mimeType="application/octet-stream")]
        [Bindable]
        private var srcXML:Class;
        function some_func():void {
        var my_xml:XML = XML(new srcXML);
      ////////////////////////////////and/////////////////////////////////////////////////////// ///
        for each (var resort:XML in srcXML){
        resortMarker = new PointMarker();
        resortMarker.addEventListener(MouseEvent.CLICK, handleMouseClick);
        _map.putMarker(new Location(resort.lat, resort.long), resortMarker);
