0 Replies Latest reply on Oct 26, 2014 12:48 PM by Ronald63
    loadPlaceGun error
    Ronald63 Level 4
      When I run the following script for the first time, I get an error (the file don't exist or you don't have the access or the file is use by another application) [InDesign CC 2014 v10.0].
      If I run it again it works. Do you have an idea to fix this ?
      Thank you for your help
      Regards
      var myFileArray= new Array;
      var OutPutFile1 = new File("~/Documents/myfile1.txt");
      var OutPutFile2 = new File("~/Documents/myfile2.txt");
      // create and  write files
      OutPutFile1.encoding = "UCS-2";
      OutPutFile1.lineFeed="Unix";
      OutPutFile1.open( "w" );
      OutPutFile1.writeln("foo1");
      OutPutFile1.close();
      OutPutFile2.encoding = "UCS-2";
      OutPutFile2.lineFeed="Unix";
      OutPutFile2.open( "w" );
      OutPutFile2.writeln("foo2");
      OutPutFile2.close(); ;
      //push files in array
      myFileArray.push(OutPutFile1);
      myFileArray.push(OutPutFile2);
      //load place gun
      app.activeDocument.placeGuns.loadPlaceGun(myFileArray);
