4 Replies Latest reply on Oct 28, 2014 2:06 AM by Ruiter Andre
    fdf import does not populate all fields
    Ruiter Andre
      We try populating a PDF with an FDF file, but not all data is showing up. On the PDF file are javascript validation checks and dependencies on visibility.
      When we manually fill the document with Acrobat XI and export the data to an FDF and try importing this file the problem already occurs.
      Is this causing the problem as I expect, and is there a way to work around this problem, without having to remove all javascript on all fields? Or is there a way to remove all the scripts easily?
      Who can help us or point us in the right direction?
