2 Replies Latest reply on Mar 26, 2007 7:16 AM by timbronze
    Timed loading
      What and how would be the best method of loading or triggering movie clips to load and play. I want to do be able to do this based on a set time style function where after say 10seconds has elapsed a movieclip will play, then after a further 10 seconds another will play.
      Any help would be greatly appreciated.
        • 1. Re: Timed loading
          use the setInterval function. it allows you to call a function at a specified interval set in milliseconds. you can also pass parameters to the function you specify.
          Here is the usage for the function:
          setInterval(functionName:Function, interval:Number [, param1:Object, param2, ..., paramN]) : Number
          it returns an integer that you can use to pass into clearInterval() to cancel the interval.
          if you need more info on it just search setInterval() in flash help.
          • 2. Re: Timed loading
            timbronze Level 1
            Cheers for the help.
            I used this and it is all working great now.
