Hi. I created a project in Captivate 8 by importing 27 PowerPoint 2010 slides. I chose the High Fidelity option when doing the import, just as I used to do in CP6, and I used 1024 x 768 resolution.
I am inserting highlight boxes on the first several slides, and as I'm doing so, the fonts on the slide seem to be arbitrarily changing resolution. My highlight boxes remain the same, but the PowerPoint-generated information keeps changing size. Oddly, the imported slide background stays the same - only the fonts and pictures get larger or smaller.
As a result, when I preview my slides, my highlight boxes show in the wrong place as compared to the text or pictures. In addition, the highlight boxes often show in the wrong places on the slide on the stage, but show corrected in the Filmstrip. I am VERY confused. Anyone have any idea how to fix this?
Thank you!
similar problem. In my case my text boxes from ppt slides change font, space between characters, level of the box.
This is my post about it
ppt slide objects lose their formatting when ineserted in cp7 project
Where are the Captivate design team to answer these questions and get this working!!! We are paying good money for Adobe products and something that worked very well in Captivate 5.5 just doesn't work in Captivate 8
If you want pixel perfect matching of your PPT, do it the Camtasia way. Present the PPT as you would normally, then record it using Captivate.
Any time you take data from one application and move it to another, there is always the risk of munging.
Cheers... Rick
Thank you Rick.
In this case we are not talking about "pixel perfect matching" but about bigger problems (change of font, change of size, change of location, lost of animations, ecc.).
I am still convinced that the CP ppt importing feature should be largely improved, from a simple reproduction of a ppt slide as an .swf in the background of a cp slide which is now (The suggested "Camtasia way" reaches to a similar solution: a video of the presentation instead of a swf: not manipulation using CP would be possible ), to a true import: an "object-by-object" import.
Many times strict deadlines do not allow to recreate slides from scratch but make it mandatory to import already existing high level ppt slides (to be, eventually, further manipulated/improved with CP) .
Just my idea.
It's your call.
You can ask Adobe for a different method and wait indefinitely to see if it ever emerges, or you can find workarounds and move forward pretty much immediately.
Cheers... Rick
