1. Re: Windows 8.1 tablet
Jeff A Wright Oct 27, 2014 3:18 PM (in response to Buzz81)Buzz81 it depends if your tablet meets and exceeds the system requirements for the applications you are wishing to install. You can find a list of system requirements at System requirements | Creative Cloud.
2. Re: Windows 8.1 tablet
Buzz81 Oct 30, 2014 6:53 AM (in response to Jeff A Wright)My specs check out for most system requirements, but I'm confused about the processor. Adobe specs require Intel Pentium 4. How does that compare to an Intel Atom (mine is Z3740D)? The Pentium 4 does not have as many cores, but may have a higher operating frequency.
3. Re: Windows 8.1 tablet
Jeff A Wright Oct 30, 2014 10:05 AM (in response to Buzz81)Buzz81 I believe the Intel Atom processor is able to duplicate the functions of a Pentium 4 processor. You can download and install a trial of the software to evaluate the performance on your computer.
4. Re: Windows 8.1 tablet
Buzz81 Nov 1, 2014 12:59 PM (in response to Buzz81)I just tried to install it with Photoshop, Illustrator, Indesign, Acrobat XI Pro and InCopy. Photoshop was first at bat, and the installation failed with the following message:
Exit Code: 6
Please see specific errors below for troubleshooting. For example, ERROR:
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 2 error(s)
----------- Payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} -----------
ERROR: Third party payload installer vcredist_x86.exe failed with exit code: -2147024546
ERROR: Failed to install Microsoft Visual C++ 2012 Redistributable Package (x86). Please try installing it by double clicking on the executable "C:\Users\Mark\AppData\Local\Temp\{E3394358-ED4F-4F67-A08E-77715B1F262E}\Photoshop_15_LS2 0_win32\Adobe CC 2014\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe", or download and install the latest Microsoft Visual C++ 2012 Redistributable Package (x86) from Microsoft website - www.microsoft.com
What's up with that? My tablet is 32 bit, not 64 bit. Is that the issue?
5. Re: Windows 8.1 tablet
Rahman Nov 2, 2014 1:35 AM (in response to Buzz81)Hi, Buzz81,
You may try the below steps:
Go to Control Panel> Programs> Programs and Features,
Find Microsoft Visual C++ 2012 Redistributable Package (x86) in the list of installed Applications.
Right click on it and then click on it and then click on 'change'
Then select Repair. (You may have to restart your computer)
Once repaired, restart your computer and try installing.
Regards,
Rahman.
6. Re: Windows 8.1 tablet
Buzz81 Nov 2, 2014 12:47 PM (in response to Rahman)Thanks - I meant to write back, but after restating the 2012 redistributable was installed and the CC applications finally installed correctly. I can't recall if I had to install the 2012 redistributable from the Microsoft webstie, but I think it installed sometime during the Photoshop installation, and, for some reason, wasn't recognized until I restarted. I had to turn the tablet off because it shut everything down except the Windows button (which couldn't even get me to the Metro screen) and the Taskbar. After restarting I was able to finish installing.
