1 Reply Latest reply on Oct 27, 2014 11:03 AM by rkelly0137
    how do you remove the white background and print only the image?
    alphagraphic
        • 1. Re: how do you remove the white background and print only the image?
          rkelly0137 Level 4
          Well, for printing you shouldn't have to remove the background.  Most printers don't print white.
          But if you want to remove the white I'd use Select > Color Range.  Make sure to check contiguous so it doesn't select the whites of the eyes (unless you want that removed too).  If it's a perfect white you can move the fuzziness all the way down.  Otherwise slide it up to get the detail you want.  Delete it, then save as a format that preserves transparency (I believe GIF should work?)
