2 Replies Latest reply on Mar 22, 2007 1:03 AM by ::E1::
    Datagrid <- XML attributes and text
    ::E1::
      Please help with this. I am trying to load XML data into datagrid. If I use only text nodes or attributes, I can get it work. But if I have mixed XML content, I cannot get data I need.
      All examples I've found so far use or just attributes or just nodes. No mixed content.
      <myDatas>
      <data id="1">
      <name nickname="jay"> JACK</name>
      </data>
      How to show all data in datagrid using HTTP service in FlexBuilder?
      <mx:DataGridColumn headerText="PROJEKT" dataField="@id"/>
      <mx:DataGridColumn headerText="ID" dataField="NAME"/>
      <mx:DataGridColumn headerText="PONUDA" dataField="@nickame"/>
      This example shows just first two of them. I cannot get nickname shown nut even using labelFunction. Also, I have more complexed XML than this.
      Please help & thank you.
        • 1. Re: Datagrid &lt;- XML attributes and text
          ntsiii Level 3
          That code has several typos.
          Check your spellng.
          Tracy
          • 2. Re: Datagrid &lt;- XML attributes and text
            ::E1:: Level 1
            Sorry for the typos Tracy. I've tryed to make it short and clear to understand the problem. Here is (I hope) more litterate version :)
            xmlFile:
            <myDatas>
            <DATA id="1">
            <NAME nick="jay">JACK</NAME>
            <SURNAME middle="what">JILL</SURNAME>
            </DATA>
            <DATA />
            </myDatas>
            part of mxml file
            <mx:HTTPService
            id="dataFeed"
            url=" http://localhost/data.xml"
            useProxy="false"
            <mx:Script>
            <![CDATA[
            private function getAttributeNick(item:Object, column:DataGridColumn):String
            return (item["NAME"]["nick"]);
            <!-- I cannot make this work but you'll get idea -->
            private function getAttributeUniversal(item:Object, column:DataGridColumn):String
            return (this["item."+ column.dataField]);
            </mx:Script>
            <mx:DataGrid dataProvider="{dataFeed.lastResult.myDatas.DATA}" >
            <mx:columns>
            <mx:DataGridColumn headerText="ID" dataField="@id"/>
            <mx:DataGridColumn headerText="NAME" dataField="NAME"/>
            <mx:DataGridColumn headerText="SURNAME" dataField="SURNAME"/>
            <-- this I cannot get to work -->
            <mx:DataGridColumn headerText="NICKNAME-!OK" dataField="NAME.@nick"/>
            <mx:DataGridColumn headerText="SUR2-!OK" dataField="SURNAME.@middle"/>
            <!-- this works but I would like not to write function for each attribute I may have -->
            <mx:DataGridColumn headerText="NICKNAME-OK" labelFunction="getAttributeNick"/>
            <!-- so I try to send in some data -->
            <mx:DataGridColumn headerText="SUR2 !OK" dataField="SURNAME.@middle" labelFunction="getAttributeUniversal"/>
            </mx:columns>
            </mx:DataGrid>
            Thank you for your interest.
