• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ColdFusion Builder 3 - Search on Open Documents produces java.lang.NullPointerException
Explorer ,
Oct 27, 2014 Oct 27, 2014
ColdFusion Search Dialog:
Works well with Search on Current Documents
Paid license.
Please Advice.
TOPICS
Builder
Views
903
Translate
Translate
Report
Report
Community guidelines
community guidelines
Nov 28, 2014 Nov 28, 2014
Can you please paste/add error screenshot for this issue?
Are you getting any error logging for this error there?
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 30, 2015 Jan 30, 2015
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 01, 2015 Feb 01, 2015
Could you show us the steps in your search process. I am unable to reproduce your settings when I open the Search menu in my version of Coldfusion Builder 3.
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 02, 2015 Feb 02, 2015
Ctrl+Alt+F>Scope: Open Documents
If this short cut doesn't work for you, look under CF Builder 3 Preferences > Keys > 'ColdFusion Search Dialog'
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 04, 2015 Feb 04, 2015
Thank you, TechFuser. I have experimented by searching on 'Open Documents', but am unable to reproduce the error. However, there indeed seems to be a problem. It failed to work for me either.
Like you, I got a NullPointerException. But that seemed to happen whenever I restarted ColdFusion Builder 3. The details are as follows:
CFBuilder Version: 3.0.0
Build: 292483
Message:
Unhandled event loop exception
Exception Stack Trace:
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
  at org.eclipse.swt.SWT.error(SWT.java:4397)
  at org.eclipse.swt.SWT.error(SWT.java:4312)
  at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
  at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
  at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
  at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
  at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
  at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
  at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
  at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
  at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
  at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
  at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
  at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: java.lang.NullPointerException
  at com.adobe.ide.coldfusion.appcodegeneration.runtime.views.ViewContributionService$1.run(ViewContributionService.java:113)
  at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
  at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
  at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
  at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
  ... 23 more
Session Data:
eclipse.buildId=unknown
java.version=1.7.0_55
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86
Votes
Translate
Translate
Report
Report
Community Expert ,
I then cleared the error log, opened 2 CFM files in the editor, and performed a search as you had done.
Builder proceeded to search the entire workspace. Even then, it failed to find the search text. When I examined the error log, I found it was populated by a pair of errors, which occurs 72 times. The errors are:
Votes
Translate
Translate
Report
Report
Community Expert ,
Please report this as a bug, including a link to this forum page
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Cheers! I have voted for it.
Votes
Translate
Translate
Report
Report
Resources
Documentation
