3 Replies Latest reply on Oct 28, 2014 12:55 AM by caststupider Branched from an earlier discussion.
    animate object with expression
    caststupider Level 1
      how can I animate an object with a expression?
      for example:
      -the object moves in 3 seconds 500px further
      -or from second 15 of the video, moves the object 500px in 3 seconds.
      and i often get this error message:
      array part can not take more than one value
      -how can I avoid what should I do
      thanks for your answers
      I hope someone can help me
      --sorry for my english i'm from Switzerland--
        • 1. Re: animate object with expression
          Dave LaRonde Level 6
          Why bother to use an expression?  You can do the same thing with keyframes and a little bit of arithmetic.
          • 2. Re: Re: animate object with expression
            Your expression needs a time reference, which returns one value, and a position reference which is either a 2 or 3 place array written like this [100, 300]
            If you want to write an expression that moves a layer from it's original position 500 pixels to the left in 3 seconds then you just have to divide 500 X 3 then use time * the result and add that value to the current position of X. I'd write it something like this:
            d = 500;  // distance in pixels
            s = 3;  // time in seconds
            r = d / s; // pixels per second
            cv = value[0];  // current value of x
            nx = cv + (time * r); // add movement to the right
            [nx, value[1]]
            Movement will start from at the first frame of the comp. You can use valueAtTime or inPoint or even the position of a marker to start the movement by simply doing a little more coding.
            • 3. Re: Re: animate object with expression
              Thank you for the answer, I will try it at home the same.
              it will certainly help me
              Now I understand the principle better already and have learned something
