1 Reply Latest reply on Oct 29, 2014 3:14 PM by brianspree
    Remote photoshop scripting over SSH
    brianspree
      I'm trying to get AppleScript scripts to execute on a remote rendering server over SSH (using the osascript command line utility). However, whenever I try to do most anything, I get various Photoshop and/or AppleScript errors that I never get when trying to run the exact same scripts locally. Ultimately, I'm trying to execute a JavaScript file passing JSON arguments from Applescript, called over SSH. Please forgive the verbosity introduced by the simple initial example.
      Server: OS X 10.8.5
      Photoshop: CC 2014
      I see the same type of errors whether I SSH into a server and do the following manually in a shell after logging in, or feed a command to SSH to execute directly (e.g., ssh user@host 'osascript /path/to/script.scpt'). Starting from a basic example, I tried running the following AppleScript snippet. I tried entering it into osascript by hand via stdin, as well as writing it out to a file and calling it remotely. Both resulted in no new file being created, but a success message.
      tell application "Adobe Photoshop CC 2014"
           make new document
      end tell
      No matter how I try to run this remotely, I get the response "document Untitled" from osascript, and Photoshop pops up an error dialog: "Could not complete your request because of a program error."
      More specific to what I'm trying to do, I've got the following code:
           with timeout of 30 seconds
                do javascript("/path/to/local/file.js") with arguments ({"{\"json\": \"document\", ...}"})
           end timeout
      end tell
      When I try to run this locally, I never have a problem. But when I run it over ssh (again, either from the command line or by passing the command directly to ssh), I always get the following:
      script error: Expected end of line but found identifier. (-2741)
      In addition to osascript stopping with that error, Photoshop also pops up the same error dialog: "Could not complete your request because of a program error."
      Anyone have any suggestions or thoughts with regard to how I can get all this working?
      Brian
