4 Replies Latest reply on Apr 18, 2009 6:55 AM by wision
    is there a way to get the cursor position index of html text field
    enfantterrible-tijzQ7
      I'm trying to work on a text pad like MC with "insert text at position X" and "find and replace" can anyone tell me how to find the cursor index of an html text field. Selection.getBeginIndex() , Selection.getEndIndex(), Selection.getCaretIndex() as far as I know these methods only work with text and not htmltext.
      What I'm trying to do is assign different parts of the string to variables so that I can combine them to reconstitute my html string.
        • 1. Re: is there a way to get the cursor position index of html text field
          Greg Dove Level 4
          enfantterrible:
          If I understand correctly, you want the corresponding position in the
          htmlText propery of the caret index (which as you point out is only the
          position in the plain text version of the textfield content).
          Below is how I would do it. Maybe there's an easier or more efficient
          way (using XML objects etc), but I don't know it. You could conduct all
          your string searches in the plain text and then convert the result to
          the html positions. I didn't build this to accept negative parameters
          for the pos parameter (e.g. from end of string backwards) but the
          function could be adapted to do this too if necessary. The test data is
          not proper html from a text field, but it doesn't really matter what it
          is so long as its formatted correctly. It just separates the tags from
          the content to enable apples with apples comparison.
          //some test data
          var testStringXML = "<format>Hel<b>lo i can't t<i>ell you h</i>ow hap</b>py I am.</format>";
          var undecoratedString = "Hello i can't tell you how happy I am.";
          //the conversion function
          function findDecoratedPosition(pos:Number, xmlString:String, test:Boolean):Number {
          //anything between '<' and '>' should be excluded from plain text search.
          //create an array of array elements (n=2) consisting of tag then plain text
          //requires correctly formatted xml/html
          var tempArr:Array = xmlString.split("<");
          for (var aa = 0; aa<tempArr.length; aa++) {
          tempArr[aa] = tempArr[aa].split(">");
          //remove the first and last elements of the new array (these are empty)
          tempArr.pop();
          tempArr.shift();
          //find the corresponding plaintext location and calculate the "decorated" position
          var retPos:Number = 0;
          var posCount:Number = 0;
          retPos += tempArr[aa][0].length+2+tempArr[aa][1].length;
          //+2 allows for missing < and >
          posCount += tempArr[aa][1].length;
          if (posCount>pos) {
          return (retPos+(pos-posCount));
          //out of range
          return -1;
          //test code:
          for (var aa = 0; aa<undecoratedString.length; aa++) {
          var altPos = findDecoratedPosition(aa, testStringXML);
          trace(undecoratedString.charAt(aa)+" in position "+aa+" plainText equates to position "+altPos+" in the decorated version ["+testStringXML.charAt(altPos)+"]");
          • 2. Re: is there a way to get the cursor position index of html text field
            Greg Dove Level 4
            Oh, and you can remove the boolean 'test' parameter... forgot to do that sorry.
            • 3. Re: is there a way to get the cursor position index of html text field
              enfantterrible-tijzQ7 Level 1
              GWD
              thanks for the input and the brillant piece of logic I was able to adapt it to fit my needs.
              Once again thanks!!
              • 4. Re: is there a way to get the cursor position index of html text field
                wision
                Hi!
                I used your AS to get the cursor position index of html text field, but I found a big problem with it! If I have an input textfiled with a simple text (not HTML) and an empty row in it, your code have a problem to get the cursor position in the HTML code! How can I solve this problem? I know your message is very old, but the solving of this problem is very, very important for me.
                Thank you, WISION
