• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
find next alpha record
Guest
Jun 29, 2007 Jun 29, 2007
Hi i have a query, which is below, just pulls info and orders by Surname.
my page displays one record at a time, so what i need is a next and previous button to go to the next surname in the table
but i am not sure how i would do this maybe an array?, can someone help.
<cfquery name="Getenq" datasource="#application.ds#">
SELECT *
FROM customerenquiryaddresses
Order By EqSurname
</cfquery>
TOPICS
Advanced techniques
Views
940
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jul 03, 2007 Jul 03, 2007
You don't need an array. There are tutorials on pagination at easycfm.com that give you the general idea of what you want to do.
If it were me, I'd be making the query a session variable and using one of the variables that come with cfquery to keep track of what record I was on.
Votes
Translate
Translate
Report
Report
Guest
Jul 04, 2007 Jul 04, 2007
ok thanks, that works well,
only one issue i have, next to the prev page and next page links, i have a surname search
this is a text box with a submit btn, lets say the surname was "SMITH", when submitted it goes to a new results page listing all matches
from this list the user can click a surname "SMITH" to go back to the main page with "SMITHS" details.
BUT
then if i click on next link, the page goes back to Adams (first in the list) instead of going to the next SMITH in the list.
so how do i click on SMITH and go back to the main page so i can use the next and previous links?
as the link i have
<a href="Page.cfm?ID=#Gets.ID#">#Gets.Surname#</a>
which is the id of the record but this obvoiulsy dosn't match the new "next and previous" code i have just put in.
Any ideas what i need to do.
Votes
Translate
Translate
Report
Report
LEGEND ,
Keep the query and the currentrow in the session state. Use the session variable with your currentrow in your anchor tag.
Votes
Translate
Translate
Report
Report
Guest
ok many thanks Dan,
i have attached my query as i am not sure what to set as a session
could you please let me know what sessions i need to set?
Votes
Translate
Translate
Report
Report
Contributor ,
Here's a suggestion:
Votes
Translate
Translate
Report
Report
Guest
Jul 05, 2007 Jul 05, 2007
ok thanks, i have added the session to the query, what do i now need to link my text link, so the query knows what record to show.
so a user types in a surname and clicks submit which send the user to a new page which displays a list of all matches.
the user then click on view record (which is next to each surname),
this then takes the user back to the main page and displays the record.
the problem is that how does the session query know where to display the surname match?
I have tried this query, on the results list page, so i could use currentrow to go back to the main page WHICH WORKS..
<cfquery name="Getsur23" datasource="#application.ds#">
SELECT *
ORDER BY EqSurname
LIMIT #start_record#, #records_per_page#
</cfquery>
<a href="EnquiryResultsInner.cfm?ID=#Getsur23.currentrow#">View Record</a>
But inside the query i need to have
WHERE EqSurname LIKE '#form.Surname#%'
so this changes the currentrow number which doesnt match the same query in the main page
any ideas?
Votes
Translate
Translate
Report
Report
LEGEND ,
you don't need the first query. One of the variables that comes with cfquery makes it unnecessary.
take the limit stuff away from your 2nd query and make it a session variable. That way you never have to run it again.
Votes
Translate
Translate
Report
Report
Guest
ok thanks,
but still not sure what you mean?, what sessions do i add to the query?
and what would i add so i can remove the first query?
thanks once again
Votes
Translate
Translate
Report
Report
LEGEND ,
Does this look like it might be usefule?
<cfquery name="session.yourquery"
What do you add so you can remove the first query? A trip to the cfquery pages of the cfml reference manual. If you don't have one, the internet does. Pay particular attention to the variables that are available after you run the query.
Votes
Translate
Translate
Report
Report
LEGEND ,
If these are your surnames:
ADAMS
ANDERSON
ANDERSON
SMITH
and the user does a search on ANDERSON.
Is there a requirement for your previous/next links to show him ADAMS or SMITH?
Votes
Translate
Translate
Report
Report
Guest
ok if the user searches ANDERSON, on the DISPLAY PAGE, this then submits to the LIST PAGE which will show any matches that start with ANDERSON.
then the user will click the record they want, and it will go back to the DISPLAY PAGE showing the details.
and yes the NEXT and PREV links then need to go through alphabetically by each record right though to A or X
i cant work out if this is possible?
Votes
Translate
Translate
Report
Report
LEGEND ,
Of course it's possible. It's hard, but it's possible.
At some point, run a query of all applicable users. That becomes your session variable.
For the search by name, do the pre version 5 edition of Query of Queries. It includes the cfloop and cfif tags. This enables you to display the records you want, complete with cfquery rownumber. Now your previous and next links can simply use the numbers 1 above and 1 below this number.
You've already added the logic for the first and last records of your query I assume.
Votes
Translate
Translate
Report
Report
Guest
Hi Dan,
i have added my code below, so you can see where i am at.
can you just let me know what code i need to change
many thanks
John
Votes
Translate
Translate
Report
Report
Guest
Jul 09, 2007 Jul 09, 2007
LATEST
ok i have decieded to just have the surname search return to the main page, and forget the results page.
so when a user types in a surname it just finds the first surname from the query, and then the next and previous buttons will fing the next previuos surname.
i have tried this code but it wont work any ideas?
<cfquery name="Sget_names" datasource="#application.ds#">
SELECT *
ORDER BY EqSurname
</cfquery>
<CFIF ISDEFINED ("form.Surname")>
<cfquery name="get_names" dbtype="query">
SELECT *
FROM Sget_names
WHERE EqSurname LIKE '#form.Surname#'
</cfquery>
<cfelse>
SELECT *
FROM Sget_names
</cfquery>
</CFIF>
Votes
Translate
Translate
Report
Report
Resources
Documentation
