1 Reply Latest reply: Oct 31, 2014 7:00 AM by AlbertoAT RSS
    Blank fields unless click.
    AlbertoAT Community Member
      Hello!
      I created a form with the adobelivecycle workbench embedded into SAP. This form contains a server signature.
      When I generate a PDF archive without signature, all works OK. But when I include the code for generate PDF with server signature, content fields has disappear unless you click into the field.
      In my case, I generate 6 different Adobe forms. Five works fine but one of them has this fail. For all, signature process is the same.
      Signature code:
      Downloading l_pdf content, works fine, but downloading l_out not work.
      TRY.
             l_pdfobj = l_fp->create_pdf_object( connection = 'ADS' ).
             CALL METHOD l_pdfobj->set_document
               EXPORTING
                 pdfdata = l_pdf.   " Here l_pdf is the PDF we just created
             CALL METHOD l_pdfobj->set_signature
               EXPORTING
                 keyname   = 'ServerSignature'      "Hace referencia al certificado
                 fieldname = 'data[0].Pagina1[0].CampoFirma2[0]'     "Campo de firmfirma
      *         reason    =
      *         location  =
      *         contactinfo =
      *    ADS call
             CALL METHOD l_pdfobj->execute( ).
      *   Signed pdf
             CALL METHOD l_pdfobj->get_document
               IMPORTING
                 pdfdata = l_out.
           CATCH cx_fp_runtime_internal INTO l_fpex.
           CATCH cx_fp_runtime_system INTO l_fpex.
           CATCH cx_fp_runtime_usage INTO l_fpex.
         ENDTRY.
      Thanks.
        • 1. Re: Blank fields unless click.
          I have solved the issue.
          In a initalize event for a group of fileds I have forced to "open" the Access property.
          The code.
          data.Pagina1.CamposCabecera::initialize - (JavaScript, client)   // Event modified.
          this.access = "open";
          Strange solution, but works.
