0 Replies Latest reply on Oct 28, 2014 10:31 AM by jpeters36
    Creative Cloud failed to install OSX
    jpeters36 Level 1
      Hello all
      I have seen similar post on windows but I am having this issue on osx (10.9.5) , the log is saying "uninstall falled installation is not present" thing is im trying to install. just out of curiosity I then ran the "uninstall pkg" and get identical errors. I have recreated the packages using creative cloud packager and this is on multiple computers so is this in the packager and is there a work around?
      thanks in advance for any assistance
      Jeff Peters
      Log file for failed set up:
      Mon Jun  9 11:33:31 PDT 2014
      creating system keychain entries
      ...Generating key pair...
      ...creating certificate...
      Serial Number      : 0A B5 10 63
      Issuer Name        :
         Common Name     : com.apple.systemdefault
         Org             : System Identity
      Subject Name       :
      Cert Sig Algorithm : OID : < 06 09 2A 86 48 86 F7 0D 01 01 05 >
         alg params      : 05 00
      Not Before         : 18:33:31 Jun 9, 2014
      Not After          : 18:33:31 Jun 4, 2034
      Pub Key Algorithm  : OID : < 06 09 2A 86 48 86 F7 0D 01 01 01 >
         alg params      : 05 00
      Pub key Bytes      : Length 140 bytes : 30 81 89 02 81 81 00 ED ...
      CSSM Key           :
         Algorithm       : RSA
         Key Size        : 1024 bits
         Key Use         : CSSM_KEYUSE_ENCRYPT CSSM_KEYUSE_VERIFY CSSM_KEYUSE_WRAP
      Signature          : 128 bytes : 80 6B 85 82 DA FC A3 21 ...
      Extension struct   : OID : < 06 03 55 1D 0F >
         Critical        : FALSE
         usage           : DigitalSignature KeyEncipherment DataEncipherment
      Extension struct   : OID : < 06 03 55 1D 25 >
         Critical        : FALSE
         purpose  0      : OID : < 06 09 2A 86 48 86 F7 63 64 04 04 >
      ..cert stored in Keychain.
      ..identity registered for domain com.apple.systemdefault.
      Serial Number      : 28 54 53 AB
      Issuer Name        :
         Common Name     : com.apple.kerberos.kdc
      Subject Name       :
         alg params      : 05 00
         alg params      : 05 00
      Pub key Bytes      : Length 140 bytes : 30 81 89 02 81 81 00 C4 ...
      CSSM Key           :
         Algorithm       : RSA
         Key Use         : CSSM_KEYUSE_ENCRYPT CSSM_KEYUSE_VERIFY CSSM_KEYUSE_WRAP CSSM_KEYUSE_DERIVE
      Signature          : 128 bytes : 2D 43 C9 F8 DE 1F 9A E6 ...
         Critical        : FALSE
         Critical        : FALSE
         purpose  0      : OID : < 06 08 2B 06 01 05 05 07 03 01 >
         Critical        : FALSE
         purpose  0      : OID : < 06 07 2B 06 01 05 02 03 05 >
      ..identity registered for domain com.apple.kerberos.kdc.
      added /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc to acl for com.apple.kerberos.kdc
      hod-admin: krb5_kt_start_seq_get: keytab /etc/krb5.keytab access failed: No such file or directory
      Done LKDC setup
      No matching processes were found
      Mon Jun  9 11:33:33 PDT 2014
      ...System identity already exists for domain com.apple.systemdefault. Done.
      ...System identity already exists for domain com.apple.kerberos.kdc. Done.
      /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc already in acl
      Done LKDC setup
      Wed Jul  9 12:00:15 CDT 2014
      Serial Number      : 3F 29 82 99
      Issuer Name        :
      Subject Name       :
         alg params      : 05 00
      Not Before         : 17:00:15 Jul 9, 2014
      Not After          : 17:00:15 Jul 4, 2034
         alg params      : 05 00
      Pub key Bytes      : Length 140 bytes : 30 81 89 02 81 81 00 B6 ...
      CSSM Key           :
         Algorithm       : RSA
      Signature          : 128 bytes : A7 34 D5 CE F4 45 AB 0F ...
         Critical        : FALSE
         Critical        : FALSE
      Serial Number      : 70 E5 7A 47
      Issuer Name        :
      Subject Name       :
         alg params      : 05 00
         alg params      : 05 00
      Pub key Bytes      : Length 140 bytes : 30 81 89 02 81 81 00 CD ...
      CSSM Key           :
         Algorithm       : RSA
      Signature          : 128 bytes : 51 DA AE DD 43 35 A2 16 ...
         Critical        : FALSE
         Critical        : FALSE
         Critical        : FALSE
      Done LKDC setup
