6 Replies Latest reply on Oct 29, 2014 8:39 AM by Todd_Kopriva
    Make work area fill available timeline space - how?
    ingvarai Level 1
      Having used After Effects for 5 years, and having fiddled with the timeline and irritated me over this for 5 years, I finally ask fo rhelp here.
      I allways adjust the work area, all the time. And I very often want the work are to fill the timeline, completely. I can use the menu, or double clik the timeline to invoke "Trim comp to work area". Do I want this? No! My comp has to maintain its length.
      I want the work area to the fill the availabe timeline space.
      It has to be a function I have overlooked, that will make this happen. Fidddling with the zoom buttons / zoom bar is not the answer. I simply want to use a shortcut key. I need this all the time!
      I am on CS6
      -Ingvar
        • 1. Re: Make work area fill available timeline space - how?
          Todd_Kopriva Level 8
          See the "Work area" section of After Effects Help:
          After Effects Help | Previewing
          • 2. Re: Make work area fill available timeline space - how?
            ingvarai Level 1
            Hi Todd,
            nothing to be seen there, answering my question.
            Or, what can I be overlooking?
            -Ingvar
            • 3. Re: Make work area fill available timeline space - how?
              "To expand the work area to the size of the composition, double-click the center of the work area bar."
              • 4. Re: Make work area fill available timeline space - how?
                Double click the center of the work area or. . .
                Select the timeline. Make sure no layers are selected and press cmnd/ctrl + alt/option + b.
                To set the work area to selected layers select the layers you want to include in the work area and use the same shortcut: ctrl/cmnd + alt/option + b.
                Other ways to do this: Press the alt/option + ctrl/cmnd + left arrow to move to the start of the timeline then press the B key. Now press ctrl/cmnd + alt/option + right arrow to move to the end of the timeline and press the B key. This trick will move to the start and end of the layer if you hold down the shift key. If you have a bunch of layers in the comp you can move to the start frame of each layer in turn by repeatedly holding down the shift key. Having a layer selected will not limit the jump to just that layer. If you use the I and O key to go to the in and out point of a layer be aware that the 0 key will take you to the last frame of the layer, not the end of the layer.
                To find more Keyboard shortcuts type keyboard shortcuts in the Search Help field in the top right corner of AE or go here: After Effects Help | Keyboard shortcuts reference
                • 5. Re: Make work area fill available timeline space - how?
                  ingvarai Level 1
                  Oh my.. I must be terrible at explaining what I want. I do appreciate your help, your suggestions in all about changing the work area, which I do not want to.
                  I will try here again:
                  I have a composition of 2500 frames.
                  I adjust the work area, setting the beginning frame to 126, and the end frame to 226. Ok? Under no circumstances I want to alter the work area's frames span of 100 frames. Your suggestions are about changing the work area's span width. But I want it to remain 100 frames.
                  My problem is that this work area now obviously is very narrow, so I want to zoom in on this.
                  The question goes like this, as in my initial post:
                  Main question:
                  What is a fast way to make the work area fill the timeline real estate, without changing its frame span.
                  I can do this in a very fiddly, cumbersome way, by altering the zoom level  and / or dragging the handles of the navigator panel on the of the timeline. What I am after, and have not found, is a way to do this using a shortcut key / clicking somewhere.
                  -Ingvar
                  • 6. Re: Make work area fill available timeline space - how?
                    Ah, I think that I understand now. You want to zoom in time such that the span shown is just the work area duration. There is no shortcut for that.
