7 Replies Latest reply on Oct 29, 2014 9:53 PM by MichaelN
    Add text to PDF based on File name
    Verlorst Level 1
      Hi Everyone,
      I am trying to set up an action sequence that will take the file name and insert it into the PDF document at various places.
      I have the following code which works to an extent but ere is the kicker......the text needs to be coloured, moveable and if possible editable
      // Add file name to footer
      var re = /.*\/|\.pdf$/ig;
      var FileNM = this.path.replace(re,"")+".pdf";
      var Path = this.path;
      var AcDate = new Date();
      var AcDateFormat = "yyyy/mmm/dd  HH:MM"
      var Box2Width = 50
      for (var p = 0; p < this.numPages; p++){
      var aRect = this.getPageBox("Crop",p);
      var TotWidth = aRect[2] - aRect[0]
             var fd = this.addField("xftDate", "text", p, [30,15,TotWidth-30-30,30]);
             fd.value =  FileNM.substring(0,20);
             fd.textSize=8; fd.readonly = true;
             fd.alignment="right";
      var bStart=(0);
      var bEnd=(TotWidth);
      flattenPages();
      The above code was found via google so its probably not all needed or efficient
      Any help would be grand
      thanx!!
