1 Reply Latest reply on May 9, 2006 4:31 AM by friendofasquid
    WSDL2JAVA tool Use
    edHPU Level 1
      I am trying to set up a web service that submits a complex data type. I have tried unsuccessfully to build nested structures/arrays to submit the complex data types for the web service and now want to use the WSDL2Java tool... I am running coldFusion MX. What are the steps in using WSDL2Java? Thanks for the help.
        • 1. Re: WSDL2JAVA tool Use
          the wsdl to java will generate stub java classes which you could use to populate complex types IF you were using java. i don't think instantiating those types using CreateObject(java) and invoking a service using cfinvoke or CreateObject(webservice) will work as CF requires structs to pass as complex types. this seems like a poor design decision to me.
          if you're using dreamweaver, it has a decent struct generator for web service types, but it's usefulness is limited with nested structures.
          if anyone knows any differently, please respond, as i am having the very same issue.
