5 Replies Latest reply: Nov 3, 2014 9:40 AM by mgustantino RSS
    mass update master pages
    mgustantino Community Member
      version 7 - I have MANY pages that are booked. I just want to find a way to easily update the master pages all at once.
        • 1. Re: mass update master pages
          Arnis Gubins CommunityMVP
          Import (File > Import > Formats) the Master pages at the book level to all selected files in the book.
          • 2. Re: mass update master pages
            Thanks so much for the info - that worked great. However I am still having a similar problem. I cannot apply all master pages to each page. If I select Format.>Master Page >Master Page Layout  then under the dialogue box no matter what combination I choose it does not apply the master page. I have to go to each page and apply it. What am I doing wrong?
            • 3. Re: mass update master pages
              You might have overrides (i.e. the text frames have been extended/shortened), additional graphic frames, etc. on your pages.
              If you use Format > Page Layout > Master Page Usage option to force FM to use the newly imported Right/Left master pages and you're not seeing any changes, check to see what the pags called "Right" and "Left" actually contain and if they match what you were importing. These two pages are reserved names that FM uses automatically. If the imported Master pages that you wan to use have different names, then you have use the "Custom" option and apply it using the required specifications of Odd/Even, numbered or named master page.
              • 4. Re: mass update master pages
                I REALLY appreciate your help. Yes I do have overrides and additional
                graphics. I am using the Format > Page Layout > Master Page Usage option.
                That is the problem - whatever I choose in this it does not apply the master
                pages I have selected.
                Marcella Gustantino
                • 5. Re: mass update master pages
                  I think I FINALLY figured it out -  the master pages that I was trying to
                  change said none - however  they were ACTULALLY right - Once I applied
                  master page right to right it worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                  Marcella Gustantino
