5 Replies Latest reply on Oct 30, 2014 1:44 AM by BEGINNER_X
    Create New Folio
    BEGINNER_X Level 3
      Hi All,
      I need to create a new folio for my document.
      Note: Folio text frame label as "FOLIO"
      1. Take folio from the Numbering and Sections
      2. Update to the first(recto) page
      3. Same folio comes to the verso page
      4. Again add +1 number to the recto page
      5. same like as for all pages
      Screenshot helps you for better clarifications,
      Input:
      Output:
      Trying Code:
      var myPages = app.activeDocument.pages;
      alert(myPages.length);
      myCounter = 0;
      for(p=0; p<myPages.length; p++)
          myCounter++
           if(myPages[p].documentOffset % 2 == 1)
                  var myTF = myPages[p].textFrames.everyItem().getElements();
                   for(t=0; t<myTF.length; t++)
                          if(myTF[t].label == "FOLIO")
                                  myTF[t].contents = String(myCounter)
                  }   //if condition closing
              else
                  }   //else closing
              }  //for loop closing
      Kindly help for my request.
      Regards
      Siraj
        • 1. Re: Create New Folio
          Jump_Over Level 5
          using similar "everyItem()" structure you could assume modifying a proper object:
          var
          mDoc= app.activeDocument,
          counter = 0, k, cID,
          labels = mDoc.pages.everyItem().textFrames.everyItem().label;
          for (k = 0; k < labels.length; k++)
            if (labels[k] == "FOLIO") {
            cID = mDoc.pages.everyItem().textFrames.everyItem().id[k];
            mDoc.textFrames.itemByID(cID).contents = String(++counter);
          Jarek
          • 2. Re: Re: Create New Folio
            BEGINNER_X Level 3
            Hi Jump_Over,
            Thanks for your valuable coding...
            My request is different, Could you please look at my output screenshot.
            Write now, I am struggle for to get the "Numbering & Section" number.   //need help here,
            (need to change the myCounter as predefined in the "Numbering & Section" in the first page)
            Almost I got my output, any other better coding is appreciable...
            myCounter = 11;
            for(p=0; p<myPages.length; p=p+2)
                     myCounter++
            myCounter = 11;
            for(p=1; p<myPages.length; p=p+2)
                     myCounter++
            Regards
            Siraj
            • 3. Re: Create New Folio
              BEGINNER_X Level 3
              Thank You All,
              I got my output....
              Any other better way or coding is appreciable..
              Warm Regards
              Siraj
              • 4. Re: Re: Create New Folio
                Jump_Over Level 5
                Are you looking for page.appliedSection.pageNumberStart ?
                var
                     mFrames = mDoc.pages.everyItem().textFrames.everyItem(),
                     mCounter = mDoc.pages[0].appliedSection.pageNumberStart,
                     k, cID,  nID, cCount;
                for (k = 0; k < mFrames.label.length; k = k+2)
                  if (mFrames.label[k] == "FOLIO") {
                       cID = mFrames.id[k];
                       cCount = String(mCounter++);
                       mDoc.textFrames.itemByID(cID).contents = cCount;
                       try {
                            nID = mFrames.id[k+1];
                            mDoc.textFrames.itemByID(nID).contents = cCount;
                       catch (_) { break; }
                Jarek
                • 5. Re: Create New Folio
                  BEGINNER_X Level 3
                  Hi Jump,
                  Thank you for your wonderful coding & valuable timing spending for me....
                  Warm Thanks
                  Siraj
