4 Replies Latest reply on Apr 12, 2007 1:30 AM by nespresso-martini
    Probably a simple question!
    henryd
      Real simple...(probably!!)
      I have a saved square-shaped .jpeg image. The image is a background gradient color i made (from an online website-helping tool)
      How do I convert/transform this shape to a circle?
      I have tried a few things but cant seem to pull it off.....
      I thought to select paths and punch a hole....no joy......create the shape using eclipse then cut out....no joy....
      There is probably a very easy way but googling the problem wasnt a help either.
      ** Ideally i guess the best thing would be to save the image as a color that could be used to fill background...?
      T H A N K S
      Would be grateful for all assistance...
        • 1. Re: Probably a simple question!
          Level 7
          Not sure what you mean by the background gradient. I suggest you upload the
          image somewhere we can see it.
          but as we enjoy working in the dark :-) Here goes...
          Two ways I would do this.
          1. Drag out your Vector Ellipse and place it approximately where you require
          it over the top of your image. Select image > Edit > Cut. Now select your
          Vector Ellipse shape and > Edit > Paste Inside. By breaking (clicking it)
          the link in the Layers panel you can make some final adjustments to the
          positioning of your image in the Circle.
          2. Drag out your Vector Ellipse and place it approximately where you require
          it over the top of your image. Fill your circle with solid white colour.
          Select both your image and your circle > Modify > Mask > Group as Mask. Ctrl
          + Alt + T to trim.
          Peter
          "henryd" <webforumsuser@macromedia.com> wrote in message
          news:etquca$jhm$1@forums.macromedia.com...
          gradient
          either.
          that
          | T H A N K S
          • 2. Re: Probably a simple question!
            henryd Level 1
            quote:
            Not sure what you mean by the background gradient. I suggest you upload the image
            It was from dynamic drive - http://tools.dynamicdrive.com/gradient/ - basically its an online tool that mixes colors...
            Thanks for the answer ill give it a go!
            • 3. Re: Probably a simple question!
              Kid_Phoenix
              Thanks. :) I needed that.
              • 4. Re: Probably a simple question!
                nespresso-martini
                Have you tried masking the square-shaped .jpg image?
                Create a elliptical item on your canvas, make sure that the layer is above the .jpg image. Create a mask on the .jpg image by selecting its layer and click the quick mask tool. Cut elliptical tool and paste it on the mask section of the .jpg image.
                I hope I'm making sense.
