22 Replies Latest reply on Jan 30, 2017 1:59 PM by maria__
    flashplayer.log Warning codes 1474 and 1475
    drewaydelott
      Hello,
      I am using an internal server to push updates to our flash player in a test environment. I have the current version of 15.0.0.189 installed on my client machines, and the same version on my internal server. I am attempting to verify functionality by examining the flashupdate.log file. It seems that everything is working, however i have 2 [warning] codes in my log and I was hoping i could get some assistance in figuring out what they are.
      My system info is this:
      Client system: Windows 7 Professional 32bit
      Client Flash Version: 15.0.0.189
      Server System: Windows Server 2012
      Server Flash Version: 15.0.0.189
      Server File Structure:
      An excerpt of my log follows. Obviously the myflashupdate.server is a placeholder for my actual server.
      <-----BEGIN LOG---->
      2014-10-28+15-46-0.198 [info] 1628 myflashupdate.server
      2014-10-28+15-46-0.198 [info] 1629 myflashupdate.servero
      2014-10-28+15-46-0.198 [info] 1614
      2014-10-28+15-46-0.198 [info] 1615
      2014-10-28+15-46-0.214 [info] 1618
      2014-10-28+15-46-0.214 [info] 1619 1063
      2014-10-28+15-46-0.245 [info] 1628 myflashupdate.server
      2014-10-28+15-46-0.245 [info] 1629 myflashupdate.server
      2014-10-28+15-46-0.245 [info] 1614
      2014-10-28+15-46-0.261 [info] 1615
      2014-10-28+15-46-0.261 [info] 1618
      2014-10-28+15-46-0.261 [info] 1604
      2014-10-28+15-46-0.261 [info] 1608
      2014-10-28+15-46-0.276 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
      2014-10-28+15-46-0.354 [warning] 1474 12044
      2014-10-28+15-46-0.354 [warning] 1475
      2014-10-28+15-46-0.354 [info] 1432
      2014-10-28+15-46-0.370 [info] 1612
      2014-10-28+15-46-0.370 [info] 1620
      2014-10-28+16-46-0.180 [info] 1628 myflashupdate.server
      2014-10-28+16-46-0.180 [info] 1629 myflashupdate.server
      <----END LOG---->
      Does this log mean my updates are working correctly (Aside from trying to pull the same version as the one installed)?
      What are the 2 Warning codes?
      Thanks you for any and all replies!
        • 1. Re: flashplayer.log Warning codes 1474 and 1475
          maria__ Adobe Employee
          hello,
          Error 1474 means the call to /pub/flashplayer/update/current/sau/currentmajor.xml has failed, and 1475 means could not retrieve currentmajor.xml.  This indicates that you do not have the curerntmajor.xml file in your directory structure.  This is a new file introduced a few releases ago and must exist at the /sau level.  I can't determine based on your screenshot if the file is present or not.  If not, please download the latest Background Update Resources package from the Adobe Flash Player Distribution | Adobe page and deploy that to your server.
          If your version XML files have version 15.0.0.189 in them the Background Update Service will not try to pull down the version posted to the server.  It'll determine that the version available is the same as the version installed and terminate the process.
          Maria
          • 2. Re: Re: flashplayer.log Warning codes 1474 and 1475
            drewaydelott Level 1
            Thanks for your reply!
            I didn't notice somehow that the folders were only listed in my screenshot. the currentmajor.xml is in the sau directory as showcased by the screenshot below. the contents are:
                 \sau\currentmajor.xml
            <version>
                  <Player major="15" majorBeta="15" />
            </version>
            \sau\15\xml\version.xml
            <?xml version="1.0" ?>
            <version>
                 <ActiveX major="15" minor="0" buildMajor="0" buildMinor="189" />
                 <Plugin major="15" minor="0" buildMajor="0" buildMinor="189" />
                 <MacPlugin major="15" minor="0" buildMajor="0" buildMinor="189" />
                 <SAUConfig checkFrequency="1" />
            </version>
            • 3. Re: flashplayer.log Warning codes 1474 and 1475
              Hello Maria,
              I am still having this issue, is there any way i could provide you more information to assist me in solving this?
              • 4. Re: flashplayer.log Warning codes 1474 and 1475
                Are you deploying the files from the package we post to the licensing page, or are you creating the files yourself?  The package contains the files in the correct folder structure and should be posted to the server in the /sau directory as they appear in the package, replacing existing files.  I would like to examine the files that currently exist on your server.  Please send me the files, using the instructions posted here, The specified item was not found..
                Thank you in advance.
                Maria
                • 5. Re: flashplayer.log Warning codes 1474 and 1475
                  I'd also like to see the network activity when the request is made to the server.  Can you use something like Charles Proxy to record the network traffic when the request to the currentmajor.xml file is made and send me the file?
                  Thank you.
                  Maria
                  • 6. Re: flashplayer.log Warning codes 1474 and 1475
                    FMCS
                    Did this got solved ? i am having the same errors.. and i cant find anywhere what these codes are about.
                    • 7. Re: flashplayer.log Warning codes 1474 and 1475
                      Hi FMCS
                      This thread is over 7 months old and the OP never replied.  I've no idea if they resolved the issue or not.  Are you hosting the Background Update resources locally, as the OP?
                      Maria
                      • 8. Re: flashplayer.log Warning codes 1474 and 1475
                        FMCS Level 1
                        Yes, in a local server.All the files are in the right place. ports 80 and 443 open.. self signed certificate installed in the web server and in the clients.. i can see currentmajor.xml in the browser and version.xml also.
                        i have version 16.0.0.305 installed in the machines and want to update to the last one available. 18.0.0.209
                        i have searched the all internet and cant find a reason for this.
                        • 9. Re: flashplayer.log Warning codes 1474 and 1475
                          Hi FMCS,
                          Are you using all of the files in the fp_background_update.cab file, or did you you already have the XML files on your local server and edited those instead of using the files from the archive?  If the latter, please provide the files you edited (see the 'how to share a document' link below)
                          What are the permissions on the files on the server?  Sometimes when copying/FTPing files, the permissions change.
                          Please do the following:
                          1. Post a screenshot of the directory structure (including files).
                          2. Enable Background Update verbose logging by adding SilentAutoUpdateVerboseLoggin=1 to the mms.cfg file at the following location:
                            • 32-bit OS: C:\Windows\System32\Macromed\Flash
                            • 64-bit OS: C:\Windows\SysWOW64\Macromed\Flash
                          3. Install the previous version (e.g. 16.0.0.305)
                          4. Run the SAU Service
                          5. After it finishes, post the contents of the FlashInstall.log file from the same location as the mms.cfg file in step 2 above.  The file may be fairly long, if so you can upload the file (and the screenshot if you want) using the The specified item was not found. instructions.
                          6. If you uploaded the file(s) post the URL to the files in your reply.
                          Maria
                          • 10. Re: flashplayer.log Warning codes 1474 and 1475
                            FMCS Level 1
                            This is a fresh installation in a lab to understand how it works to later implement in a production environment.
                            The xml files are the ones extractod from the cab file.
                            i already have the SilentAutoUpdateVerboseLoggin=1 in the file.
                            This is the error i get.
                            The log shows the following warnings
                            2014-10-15+14-22-2.771 [info] 1628 updates.domain.local
                            2014-10-15+14-22-2.771 [info] 1629updates.domain.local
                            2014-10-15+14-22-2.771 [info] 1614
                            2014-10-15+14-22-2.771 [info] 1615
                            2014-10-15+14-22-2.771 [info] 1618
                            2014-10-15+14-22-2.771 [info] 1619 1063
                            2014-10-15+14-22-2.786 [info] 1628 updates.domain.local
                            2014-10-15+14-22-2.786 [info] 1629 updates.domain.local
                            2014-10-15+14-22-2.786 [info] 1614
                            2014-10-15+14-22-2.786 [info] 1615
                            2014-10-15+14-22-2.786 [info] 1618
                            2014-10-15+14-22-2.786 [info] 1608
                            2014-10-15+14-22-2.786 [info] 1604
                            2014-10-15+14-22-2.786 [info] 1631 /pub/flashplayer/update/current/sau//currentmajor.xml
                            2014-10-15+14-22-2.833 [warning] 1470 12175
                            2014-10-15+14-22-2.833 [warning] 1474 183
                            2014-10-15+14-22-2.833 [warning] 1475
                            2014-10-15+14-22-2.849 [info] 1432
                            2014-10-15+14-22-2.849 [info] 1612
                            2014-10-15+14-22-2.849 [info] 1620
                            What permissions should be on the files ??  I didnt look at those.. but i will monday.
                            Also i will run wireshark and see if i can find some useful information.
                            Thank you.
                            • 11. Re: flashplayer.log Warning codes 1474 and 1475
                              Hi FMCS,
                              • Using the browser, navigate to the curentmajor.xml file using HTTPS.
                                • Post a screenshot of the results
                              • Post a screenshot of the /pub/flashplayer/update/current directory tree showing each sub-directory in the tree (do not write an outline as in the first post in this discussion, post a screenshot of the actual directory tree)
                              • Provide a complete FlashInstall.log file for an impacted system.  Since this will most likely be fairly long, you can upload the file using the The specified item was not found. instructions.
                                • Post the URL in your reply.
                              Thank you.
                              Maria
                              • 12. Re: flashplayer.log Warning codes 1474 and 1475
                                thanhn19432897
                                I have the same errors what was the fix to this issue?
                                • 13. Re: flashplayer.log Warning codes 1474 and 1475
                                  There was no follow-up post from the OP to my requests, so I don't know if they fixed the issue or not.
                                  Since the OPs in this topic were all hosting the Background Update resources locally, I'm assuming you are too.  I'll need more information from you to troubleshoot the error:
                                  • What is the operating system, including version, the files are being hosted on?
                                    • Please confirm that the files are deployed correctly and appropriate access to the required ports has been granted
                                  • What is the operating system, including version, of the client system that is failing to update?
                                  • Post an excerpt of the log file, like the previous OPs did showing more details.  Simply posting the error code is not enough. For privacy, you can obfuscate your domain as the OPs did
                                  • Are you using the files from the fp_background_update.cab or from elsewhere?
                                  • Screenshot/layout of the directories and files as deployed on your local server
                                  • copy/paste the contents of the currentmajor.xml file
                                  Essentially, please provide the same information the OP posted, and information I had requested from the OP.
                                  Thank you.
                                  Maria
                                  • 14. Re: flashplayer.log Warning codes 1474 and 1475
                                    thanhn19432897 Level 1
                                    content from /24/xml/version.xml
                                    <?xml version="1.0"?>
                                    -<version> <ActiveX buildMinor="194" buildMajor="0" minor="0" major="24"/> <Plugin buildMinor="194" buildMajor="0" minor="0" major="24"/> <Pepper buildMinor="194" buildMajor="0" minor="0" major="24"/> <MacPlugin buildMinor="194" buildMajor="0" minor="0" major="24"/> <MacPepper buildMinor="194" buildMajor="0" minor="0" major="24"/> <SAUConfig checkFrequency="1"/> </version>
                                    Windows server 2008 R2, fp_background_update.cab is most current from your distribution.
                                    Log File
                                    2017-1-25+23-53-0.141 [info] 1608
                                    2017-1-25+23-53-0.173 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                                    2017-1-25+23-53-0.219 [warning] 1470 12175
                                    2017-1-25+23-53-0.219 [warning] 1474 183
                                    2017-1-25+23-53-0.219 [warning] 1475
                                    2017-1-25+23-53-0.219 [info] 1432
                                    2017-1-25+23-53-0.219 [info] 1612
                                    2017-1-25+23-53-0.219 [info] 1620
                                    2017-1-26+0-53-0.13 [info] 1628 flashupdate.domain.local
                                    2017-1-26+0-53-0.44 [info] 1629 flashupdate.domain.local
                                    2017-1-26+0-53-0.44 [info] 1614
                                    2017-1-26+0-53-0.44 [info] 1615
                                    2017-1-26+0-53-0.106 [info] 1618
                                    2017-1-26+0-53-0.106 [info] 1619 1063
                                    2017-1-26+0-53-0.122 [info] 1628 flashupdate.domain.local
                                    2017-1-26+0-53-0.122 [info] 1629 flashupdate.domain.local
                                    2017-1-26+0-53-0.122 [info] 1614
                                    2017-1-26+0-53-0.122 [info] 1615
                                    from the currentmajor.xml file
                                    <version>
                                    <Player major="24" majorBeta="24"/>
                                    </version>
                                    my clients are able to access the file via
                                    https://flashupdate.domain.local/pub/flashplayer/update/current/sau/currentmajor.xml
                                    • 15. Re: flashplayer.log Warning codes 1474 and 1475
                                      Thank you for posting the screenshots, very helpful.  We are investigating further and I'll post back soon.
                                      • 16. Re: flashplayer.log Warning codes 1474 and 1475
                                        Hi thanhn19432897
                                        Can you please access https://flashupdate.domain.local/pub/flashplayer/update/current/sau/currentmajor.xml  from the browser and check to see if there are https warnings?
                                        Thank you.
                                        Maria
                                        • 18. Re: flashplayer.log Warning codes 1474 and 1475
                                          Is flashupdate.domain.local the actual name of your server, or is that pseudo-name to obfuscate your actual local server name?
                                          • 19. Re: flashplayer.log Warning codes 1474 and 1475
                                            It is just a pseudo-name to obfuscate your actual local server name.
                                            • 20. Re: flashplayer.log Warning codes 1474 and 1475
                                              What OS versions, and browser versions are on the client systems?
                                              Please also verify, and confirm that the Common Name (CN) of the ssl certificate is the same as your local server (flashupdate.domain.local).
                                              <edited>
                                              • 22. Re: flashplayer.log Warning codes 1474 and 1475
                                                Can you please check that the CA that is associated with the self signed ssl certificate is not installed correctly for use by services?  The section titled "To add the Certificates snap-in to an MMC for a service" at
                                                https://technet.microsoft.com/en-us/library/cc754431(v=ws.11).aspx contains more information on this.
