0 Replies Latest reply: Oct 29, 2014 9:48 AM by gloomyBrain RSS
    AIR Native Extensions. How to loop FREObject properties?
    gloomyBrain Community Member
      Hello.
      We're working on a new AIR Native Extension, the goal is to run javascript code inside AIR. However that's actually not directly related to the problem.
      The problem itself:
      - we need to pass some AS3-objects to the javascript runtime
      - javascript runtime (SpiderMonkey) has a different GC, different memory aligning and a lot of other things, that differs from AIR
      - the only suitable way for us is to iterate through AS3-Object properties and to create a mirror-object in SpiderMonkey
      - we do not have such an API in FlashRuntimeExtensions.h which would allow us to iterate Object properties
      So the question is - is there any way to iterate on AS3-Object properties in С/С++ side of a Native Extension?
      If there is not than the only possibility for us is to use JSON-strings which is actually far from optimal.
      Thanks in advance,
      Denis
