When I try to install flash player on my Mac, I get to the panel that asks for my name and password, but it will not take my password. Tried changing the password, but same result. Suggestions??
This password prompt is presented by your operating system, and is intended to keep you from accidentally installing software.
If this is your personal machine and you don't need a password to log into the computer when it first starts up, you can probably leave the password blank and click OK to get past this prompt. If this is your personal machine and your normal password isn't working, check to make sure that CAPS LOCK is off, and type the password carefully.
If this is your work machine and
...Copy link to clipboard
If this is your work machine and it's asking for an Administrator password, well, you'll need to have a conversation with your friendly IT person.
It worked! Thanks so much for your help.
I am unable to push past the window asking for password. I have changed it, logged into Adobe help, sent here. A hint pops up that has nothing to do with the reset password.
I successfully set up name, email address and password and am able to login. But in trying to update the flash player, it won't accept my password, just jiggles. Stuck
Doesn't work for me. It still jiggles and won't let me update Adobe flash player.
If you're still stumped, you may need to reset the password on your Mac:
http://support.apple.com/kb/PH18653
