1 Reply Latest reply on Oct 30, 2014 2:49 AM by Doc Maik
    selecting images
    ian_v
      Need some help.
      I am working in a document containing 200 pages. I placed the images of the entire document in one layer "layer: images". Now I want to adjust all the effects of every image in the document at once. But when I do "ctrl A", it only selects the images in the page that I am working in. I want to select all the images of the entire document at once. Does anyone know how to do this?
      Thnx
        • 1. Re: selecting images
          Doc Maik Level 4
          Given that the images don't have a certain object format applied or all use the same you use Find/Replace, switch to tab "Object" and set the target object format and "graphics frame" and then run "Replace all". It will then apply the effect on all graphic frames containing an image.
