3 Replies Latest reply on Mar 21, 2007 9:12 AM by kglad
    Importing Class
    numerical07 Level 1
      I was reading the tutorial on importing class's. This is what I read
      Importing classes
      To reference a class in another script, you must prefix the class name with the class's package path. The combination of a class's name and its package path is the class's fully qualified class name. If a class resides in a top-level classpath directory--not in a subdirectory in the classpath directory--then its fully qualified class name is its class name.
      To specify package paths, use dot (.) notation to separate package directory names. Package paths are hierarchical, where each dot represents a nested directory. For example, suppose you create a class named Data that resides in a com/xyzzycorporation/ package in your classpath. To create an instance of that class, you could specify the fully qualified class name, as shown in the following example:
      var dataInstance = new com.xyzzycorporation.Data();
      My Question is about com/xyzzycorporation/ . would the full class parth be c:/com/xyzzycorporation/ . Why do they never state the drive letter when teaching about directories.
        • 1. Re: Importing Class
          SymTsb Level 2
          Because there is no need. you don't need to reference the drive letter.
          Here's the basic jist of what they are saying....
          Single Class File...
          If you create your own custom class and want to use it in your flash file, save it into the same directory as the fla file and call the classes constructor. By default flash will look inside the folder where the fla resides in for the class files if it cannot find it inside the default directory.
          Multiple Class Files - 1 Project (often referred to as packages)
          Use your qualified domain name but backwards.....
          my domain is www.sd-dezign.com so if I was going to include a package of utility class files in my document I would do the following
          Create a folder in the same folder with my fla name it com and inside that a folder called sddezign and inside that utils and all my as files would be in there...the folder structure might look like this....
          To call the constructor for each class, I have two options. The first which is by far the easiest looks like this
          In whatever frame you need to call that class constructor
          include "com.sddezign.utils.*";
          var myBox:Box = new Box();
          The second method requires more typing and can get tedious
          var myBox = new com.sddezign.utils.Box();
          Hope this helps you a bit better.
          • 2. Re: Importing Class
            numerical07 Level 1
            But what is this com directory. Is that a actual directory or is people just using that for an example. Do i have to put my classes inside this com directory and then put it in any sub directory within the com directory? What if I wanted to save my class file in C:/mydocuments/myfiles/myfla/script.as . would it be mydocuments.myfiles.myfla.script.as ???
            • 3. Re: Importing Class
              com is an actual directory. the use of com/yourwebsitename is a convention to prevent name collisions in case you download someone else's class files and they happen to create a class with the same name as one of your classes or one of your other downloaded classes. because your websitename.com is unique com/websitename should be unique to everyone.
              so, you don't have to follow convention. you could put your class file anywhere on your computer or network and, as long as the path is specified, flash will find it.
