7 Replies Latest reply on Oct 31, 2014 9:22 AM by Sajeev Sridharan
    Can you help me with this script
    hamdifem Level 1
      with the following command in the master page object style (AA1) I'm active
      var d = app.activeDocument;
      function myFindObjStyle(a) {
      var x, i;
      for(i = 0; i < a.length; ++i) {
      if(i == a.length - 1) {
      x = (x ? x : d).objectStyles.item(a[i]);
      if(!x || !x.isValid) return null;
      } else {
      x = (x ? x : d).objectStyleGroups.itemByName(a[i]);
      return x.isValid ? x : null;
      function paragraphByNesneStilWp(stil) {
      var tests = [], i, j, it, p, finded;
      for(i = 0; i < d.pages.length; ++i) {
      p = d.pages.item(i);
      if(p && p.isValid) {
      pi = p.pageItems;
      finded = false;
      for(j = 0; j < pi.length; ++j) {
      it = pi[j];
      if(it && it.appliedObjectStyle == stil) {
      finded = true;
      tests.push({pr: it, sn: i});
      break;
      if(!finded) {
      pi = p.masterPageItems;
      it = pi[j];
      tests.push({pr: it.override(p), sn: i});
      break;
      return tests;
      var FobjectStyle, objectss;
      FobjectStyle = myFindObjStyle(["AA1"]);
      if(!FobjectStyle) {
              alert("no style");
      objectss = paragraphByNesneStilWp(FobjectStyle);
      I want that my
      two pages increasing (Exercise - 1  Exercise - 1  Exercise - 2  Exercise - 2  ...)
      as the picture
      Can I place into the script
        • 1. Re: Can you help me with this script
          Sajeev Sridharan Level 4
          Try this,
          k=1;
          var x, i;
          } else {
          pi = p.pageItems;
          finded = false;
          it = pi[j];
          finded = true;
          break;
          if(!finded) {
          it = pi[j];
          //pi[j].insertionPoints[0].contents="sajeev";
          break;
          pi = p.pageItems;
          it = pi[j];
              pi[j].select();
              if(i % 2 == 0)
                  pi[j].insertionPoints[0].contents="Example " + (k);
              else
                  k++;
          break;
          return tests;
          if(!FobjectStyle) {
                  alert("no style");
          Vandy
          • 2. Re: Can you help me with this script
            hamdifem Level 1
            thank you
            When I run the command a second time
            delete the text in the text frame rewrite
            I want to change the font and size
            pi = p.pageItems;
            it = pi[j];
                var p;
                it.select();
                p = it.paragraphs[0]; // ????????????????????
                if(i % 2 == 0)
                    p.contents="TEST - " + (k);
                else
                    k++;
            p.appliedFont = "Swis721 Cn BT";
                p.pointSize = 30;
            • 3. Re: Re: Can you help me with this script
              Try this,
              k=1;
              var x, i;
              } else {
              pi = p.pageItems;
              finded = false;
              it = pi[j];
              finded = true;
              break;
              if(!finded) {
              it = pi[j];
              break;
              pi = p.pageItems;
              it = pi[j];
                  pi[j].select();
                  pi[j].insertionPoints[0].appliedFont = "Swis721 Cn BT";
                  pi[j].insertionPoints[0].pointSize = 30;
                  if(i % 2 == 0)
                      pi[j].insertionPoints[0].contents="Test - " + (k);
                  else
                      k++;
              break;
              return tests;
              if(!FobjectStyle) {
                      alert("no style");
              Vandy
              • 4. Re: Can you help me with this script
                hamdifem Level 1
                remove and over it I wanted to write
                • 5. Re: Re: Can you help me with this script
                  If you are run the same script it wont give the result, try the below code,
                      app.findGrepPreferences = app.changeGrepPreferences = null;
                      app.findGrepPreferences.findWhat = "Example - ";
                      found = app.activeDocument.findGrep (true);
                      for (j = 0; j < found.length; j++)
                          found[j].select();
                          if(found[j].parentTextFrames[0].appliedObjectStyle.name == "AA1")
                              found[j].texts[0].select();
                  //            found[j].texts[0].appliedParagraphStyle = "myParaStyle";
                  //If you want to change the style then create a paragraph style according to your requirement and mention your style name in the above line
                              app.changeGrepPreferences.changeTo  = "Test - ";
                              app.selection[0].changeGrep();
                  Vandy
                  • 6. Re: Can you help me with this script
                    hamdifem Level 1
                    "Test - 1"   >  I want to change the locations of the text  >  "1 - Test"
                        app.findGrepPreferences.findWhat = "(.+?) - (\d+)";
                            found[j].select();
                                app.changeGrepPreferences.changeTo = "$2 - $1";
                    • 7. Re: Can you help me with this script
                      Try this,
                          app.findGrepPreferences.findWhat = "(Test) - (\\d+)";
                      app.findGrepPreferences.appliedParagraphStyle= "myParaStyle";
                      app.activeDocument.changeGrep();
                      Vandy
