1. Re: Flash CS6 Cant see any extension
Jonathan Ferman Oct 31, 2014 6:26 AM (in response to redclaudious)Do you have any extensions installed? It should show up if you have any extensions or panels that show up in Flash Pro. If you do not have any you can use the Adobe Exchange Panel or try installing it and it should show up under Window>Extensions within Flash Pro CS6.
2. Re: Flash CS6 Cant see any extension
redclaudious Oct 31, 2014 6:38 AM (in response to Jonathan Ferman)I using Adobe Master Collection CS6
at first, i trying to install Keyframe Caddy (dont aware of that error, cause up till now i only use photoshop and illu)
i downloaded and installed Adobe Exchange, Extension manager showed it installed
photoshop and illustrator have Exchange Panel installed (also with other installed extensions)
if we dont have any extension, the arrow Extension button should be gray or disabled, right ?
3. Re: Flash CS6 Cant see any extension
K.Woods Nov 3, 2014 2:42 AM (in response to redclaudious)In CS6, it will be in the Windows->Other Panels menu. It is only in the Extensions menu for CC users. Hope that helps.
