1. Re: Why Does Adobe Captivate 8 Web Object Not Get Published Correctly
Sreekanth_S Oct 31, 2014 3:30 AM (in response to Akshay Iyer)Web Object should ideally be tested on a webserver or Scorm cloud.
Don't think it will work in PDF.
Sreekanth
2. Re: Why Does Adobe Captivate 8 Web Object Not Get Published Correctly
mohanadas Oct 31, 2014 4:50 AM (in response to Akshay Iyer)Hi Akshay,
I am assuming the method you are using now is embedding Youtube videos into your Web object. My suggestion is it will be much easier if you use the Youtube Learning Interaction instead of a Web object to insert Youtube videos to your Captivate project.
This can be found in the Interactions Toolbar -> Learning Interactions -> Youtube
Also, as Sreekanth mentioned, please test it on a web server, or SCORM cloud.
Youtube interaction will work when exported to PDF as well.
Regards,
Mohana
3. Re: Why Does Adobe Captivate 8 Web Object Not Get Published Correctly
Akshay Iyer Oct 31, 2014 5:48 AM (in response to mohanadas)Thank you so much Mohana.. This worked for me brilliantly and solved a really irritating problem that I had been working with for some time. I work in a product company to do give my best to the product team who came up with the feature. Loved it.
