7 Replies Latest reply: Nov 3, 2014 8:18 AM by kglad RSS
    Serious Help! Handling Sound Position And Speed!
    PardeepActionscriptPro Community Member
      Take a look at this: https://sites.google.com/site/pardeepgames/Untitled-1.swf. It may take some time to load, sound is 42 seconds, see the second text field for time buffering.
      I recommend reading the Source Code below first.
      Now as you can see the pitch and speed functions are working perfectly, but the problem is that when you move the slider, the songTime text field dosen't work correctly. When you raise the pitch the songTime should just speed up the counting not change it's position, same when you lower the pitch, it should just slow down the counting not change it's position. Well that isn't working for me. The Source Code is there for you below and all the information you need is in the comments in the code. Please help me out. Oh and I recommend focusing on the songTime text field and then moving the slider.
      Source Code:
      Name of the slider: "slider".
      Name of the first text field: "songTime".
      Name of the second text field: "songTotalTime".
      import flash.events.Event;
      import flash.events.SampleDataEvent;
      import flash.media.Sound;
      import flash.net.URLRequest;
      import flash.utils.ByteArray;
      import fl.events.SliderEvent;
      import flash.media.SoundChannel;
      var _playbackSpeed:Number = 2;
      var sound:Sound;
      var sound2:Sound; // Copy of the original sound, to get the right information about the sound because the pitch shifting for the original sound variable ruins it up.
      var myChannel:SoundChannel = new SoundChannel();
      var _loadedMP3Samples:ByteArray;
      var _phase:Number;
      var _numSamples:int;
      var request:URLRequest = new URLRequest("https://sites.google.com/site/pardeepgames/Not%20Afraid%20Instrumental.mp3");
      var songTimeTime:Number = 1000; // The variable that allows the songTime's speed to change accoriding to the value of the slider. See in line 32.
      loadAndplay10(request);
      addEventListener(Event.ENTER_FRAME, enterFrame);
      function enterFrame(event:Event):void
        progressBar.scaleX = myChannel.position / sound2.length;
        _playbackSpeed = slider.value;
        songTimeTime = 1000 / slider.value;
        songTime.text = convertTime(myChannel.position);
        songTotalTime.text = convertTimeLength(sound2.length);
      function loadAndplay10(request:URLRequest):void
        sound = new Sound();
        sound2 = new Sound();
        sound.addEventListener(Event.COMPLETE, mp3Complete);
        sound.load(request);
        sound2.load(request);
      function playLoadedSound(s:Sound):void
        var bytes:ByteArray = new ByteArray();
        s.extract(bytes, int(s.length * 44.1));
        play10(bytes);
      function mp3Complete(event:Event):void
        playLoadedSound(sound);
      function play10(bytes:ByteArray):void
        stop10();
        sound.addEventListener(SampleDataEvent.SAMPLE_DATA, onSampleData);
        _loadedMP3Samples = bytes;
        _numSamples = bytes.length / 8;
        _phase = 0;
        myChannel = sound.play();
      function stop10():void
        if (sound)
        sound.removeEventListener(SampleDataEvent.SAMPLE_DATA, onSampleData);
        myChannel.stop();
      function onSampleData( event:SampleDataEvent ):void
        var l:Number;
        var r:Number;
        var outputLength:int = 0;
        while (outputLength < 2048)
        // until we have filled up enough output buffer
        // move to the correct location in our loaded samples ByteArray
        _loadedMP3Samples.position = int(_phase) * 8;// 4 bytes per float and two channels so the actual position in the ByteArray is a factor of 8 bigger than the phase
        // read out the left and right channels at this position
        l = _loadedMP3Samples.readFloat();
        r = _loadedMP3Samples.readFloat();
        // write the samples to our output buffer
        event.data.writeFloat(l);
        event.data.writeFloat(r);
        outputLength++;
        // advance the phase by the speed...
        _phase +=  _playbackSpeed;
        // and deal with looping (including looping back past the beginning when playing in reverse)
        if (_phase < 0)
        _phase +=  _numSamples;
        else if (_phase >= _numSamples)
        _phase -=  _numSamples;
      function convertTime(milliSeconds:Number):String
        var Minutes:Number = (milliSeconds % (songTimeTime * 60 * 60)) / (songTimeTime * 60);
        var Seconds:Number = (milliSeconds % (songTimeTime * 60 * 60)) % (songTimeTime * 60) / songTimeTime;
        if (Minutes < 10)
        var displayMinutes:String = "0" + Math.floor(Minutes);
        else
        displayMinutes = Math.floor(Minutes).toString();
        if (Seconds < 10)
        var displaySeconds:String = "0" + Math.floor(Seconds);
        else
        displaySeconds = Math.floor(Seconds).toString();
        return displayMinutes + ":" + displaySeconds;
      function convertTimeLength(milliSeconds:Number):String
        var Minutes2:Number = (milliSeconds % (1000 * 60 * 60)) / (1000 * 60);
        var Seconds2:Number = (milliSeconds % (1000 * 60 * 60)) % (1000 * 60) / 1000;
        if (Minutes2 < 10)
        var displayMinutes2:String = "0" + Math.floor(Minutes2);
        else
        displayMinutes2 = Math.floor(Minutes2).toString();
        if (Seconds2 < 10)
        var displaySeconds2:String = "0" + Math.floor(Seconds2);
        else
        displaySeconds2 = Math.floor(Seconds2).toString();
        return displayMinutes2 + ":" + displaySeconds2;
